20 Most Recent Samsung RF4267HARS 25.5 Cu. Ft. French Door Refrigerator with Thru-the Questions & Answers
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Samsung... | Answered on Jun 16, 2013
CALL YOUR LOCAL REPAIR SHOP , IT NEEDS FREON ADDED AND YOU CAN NOT DO IT YOURSELF
Samsung... | Answered 3 days ago
Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately. Or try pressing the power freeze and vacation buttons for about 3 secs and it worked great.
Samsung... | Answered on Dec 07, 2019
figure out if its mounted than if its not figure out what its stuck on
Samsung... | Answered on Dec 02, 2019
try samsungs website and download the owners manual for it. it'll be in there
Error Code 6 E is due to a faulty defrost sensor. You should contact Samsung customer service.
Samsung... | Answered on Nov 30, 2019
Hi ,the # u r giving is for the water filter. Need to find source of water that is leaking in area. Remove and replace Filter. Use hairdryer to release bucket.
Samsung... | Answered on Nov 27, 2019
Every model is a bit different, but there should be an ice maker option on the control panel. Your best bet is to look in your owners manual or do a search for your model number online.
Samsung... | Answered on Nov 26, 2019
CALL A LOCAL REPAIRMAN
Samsung... | Answered on Nov 21, 2019
No one can help as you have not actually said what the problem is? It just says "Problem with Samsung Ref." Without any info all anyone can do is suggest going to the Samsung website, find the customer service number and give them a call. Sometimes they will also have troubleshooting on their site under support.
Samsung... | Answered on Oct 30, 2019
hello emer - some good stuff on samsung diy
click here samsung fridgefreezer problems
also check out these videos
Samsung... | Answered on Oct 29, 2019
Contact Samsung directly to order the repair manual.
Samsung... | Answered on Oct 28, 2019
Water filters are usually in the top at the back of the food compartment , it may be behind a box or panel. Check your owners manual. The Owner usually has to change these filters every 6 months or so.
Samsung... | Answered on Oct 23, 2019
Samsung RF4267HARS 25.5 Cu. Ft. French Door Refrigerator with Thru-the Logo
1 questions posted
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
change water filer rf4267hars 25 5 ft
  • Refrigerators
