20 Most Recent
LeapFrog Clickstart My First Computer Pink Leap Frog Questions & Answers
Get to my email address [email protected] please
Point your web browser at
One account All of Google
If another account comes up, sign out of it by clicking the avatar in the upper-right then clicking "Sign out."
If you then still can't sign in to your account, click the "Need help?" link on the sign-in page.
If you're getting an error message, what does it say?
12/31/2014 3:40:57 PM •
LeapFrog...
Answered
on Dec 31, 2014
Leapfrog mouse doesn't respond on screen
We had this happen within the first 30 minutes that we owned the Click Start! It still happens periodically when the kids are using it. For us the LED lights are flashing non-stop on the keyboard, and the mouse does not move the cursor on the screen and you cannot "click" on anything either.
Solution: On the underside of the keyboard is a very tiny hole. Push a pin or a paper clip into it, you'll feel some give in there like you are pushing a button. I push it until the lights stop flashing on the keyboard. It's the reset button. So far this has worked for us everytime.
Good luck.
5/23/2013 4:34:48 PM •
LeapFrog...
Answered
on May 23, 2013
The tv picture continues to
1.Make sure the yellow video connector is fully inserted in the correct input jack on the TV.
>Make sure the SCART connector or Euro-connector is correctly inserted in the SCART input on the TV.
>Make sure the correct colored cable in the unit is plugged into the matching video input jack o the SCART connector.
>Adjust the volume settings on your TV.
>You will also want to make sure you are plugging the video cables into the correct input on our TV. Please see picture below:
Note: In this example you would want to make sure the cables are plugged into the following inputs. You may have a VCR or DVD Player that are already using these inputs, and may have to be discounted while you are using the Clickstart.
2.Make sure the PAL(Europe)/NTSC (USA/Canada) switch is in the correct position. The switch is located in the console's battery compartment. Turn the console off before switching between PAL and NTSC
8/27/2011 4:57:47 PM •
LeapFrog...
Answered
on Aug 27, 2011
Game is working, but no
If this is a game which feeds a television monitor, the first thing to check is the cables between the game and the television or monitor. Likely there is a mismatch of cabling. The jacks from the game are not the same type of jacks at the monitor. If the game feeds composite video down one cable and it is plugged into the jack which accepts component video, the cables for the color are Pb and Pr or similar lettering.The monitor is looking for color information and is not receiving it from the game. Check the cables at each end to make sure there is a match in the outputs of the game to the inputs of the monitor.
8/4/2011 4:37:32 PM •
LeapFrog...
Answered
on Aug 04, 2011
The mouse won't work, we've
there are many things that could cause this problem most are easily addressed, by Leap Frog costumer support you can contact them at 1-800-701-5327......GOOD LUCK
1/29/2011 7:37:56 PM •
LeapFrog...
Answered
on Jan 29, 2011
Clickstart game
Same problem; it happened when my daughter got over 999 boot boxes, the counter wrapped, the problem occurred. If you create or play under a new profile it works fine.
3/25/2010 2:29:29 AM •
LeapFrog...
Answered
on Mar 25, 2010
The mouse for my son's first computer mouse
Try reinstalling the mouse driver. hook up an external usb mouse into the tower, or just tab your way into the internet, and google a mouse driver download. if that doesnt work just stick to the external mouse.
2/5/2010 6:12:17 PM •
LeapFrog...
Answered
on Feb 05, 2010
Leapreader won't turn off
Try pressing the on/off button to turn it off. I had a same problem. I depressed the on/off button for ~6 second or so and the device turned off. When I turned on again, the LeapReader no longer had a white light and was recognized by my computer.
Leapfrog leappad won't turn off
my leap pad ultra is at that part of turning off wher their is only a dot of wite left on the screen.it is still doing that and it has been at least 2 hours since i played it. it wont turn on either now.i am a kid sorry if their are spelling errors
