20 Most Recent LeapFrog Leapster 2 Learning System Questions & Answers
0answers
How do i access the speaker in the leapster 2
Can you put something like foam or a cotton ball in line with the speaker so that when you put the back on, it puts pressure on it?
3/24/2017 10:21:11 PM • LeapFrog... • Answered on Mar 24, 2017
2answers
How to fix Leapfrog Leapster 2 electronic board?
Leapster 2 Customer Support ' Online Help, FAQ, LeapFrog ...
www.leapfrog.com > Support > Products
LeapFrog EnterprisesVisit our customer support page for LeapFrog's Leapster 2 for help and answers to your product questions.Missing: electronic ‎board
How to fix Leapfrog Leapster 2 electronic board? - Fixya
www.fixya.com/support/t26040145-fix_leapfrog_leapster_2_electronic
35 mins ago - ... 2 electronic board? I know how to solder and basic principles ofelectronic parts. Know - LeapFrog Leapster 2 Learning System question.
LeapFrog LeapPad2 Explorer Troubleshooting - iFixit
https://www.ifixit.com/.../LeapFrog_LeapPad2_Explorer_Troublesh...
iFixitDrained/bad battery; Bad display; Water damage; Bad logic board ... Instructions toreplace the battery can be found at LeapFrog LeapPad2 Explorer Battery ...
Leapster 2 Quick Fix Tutorial - YouTube
? 3:02 https://www.youtube.com/watch?v=eQayGCjEdgo Jan 22, 2009 - Uploaded by filterdragon Tutorial on how to fix your child's Leapster 2. If your Leapster 2has a problem other than the screen not registering the stylis pen, please go to the Leaps... ... Ana E 1 year ago .... 2:34. leap frogleappad repair guide.
2/19/2016 12:00:53 PM • LeapFrog... • Answered on Feb 19, 2016
Leapster restarts select cartridge game
Try this Ensure that a cartridge is not inserted Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
8/13/2014 5:19:37 AM • LeapFrog... • Answered on Aug 13, 2014
What to do after resetting Leapster 2 and touching with pen isn't working?
run a toothpick around the screen under the plastic frame and pick out dirt, food particles etc. and see if this helps. Do it very carefully not to damage the screen.
7/3/2014 5:20:18 AM • LeapFrog... • Answered on Jul 03, 2014
System crashes when program starts
send it back to the company
6/23/2014 10:15:43 PM • LeapFrog... • Answered on Jun 23, 2014
Www leapfrog com connect
The Li-on battery is discharged too far. Contact leapfrog and see if they can repair it.
5/23/2014 3:19:25 AM • LeapFrog... • Answered on May 23, 2014
Start using the leapster and it just shuts off and even the batteries are guarenteed to last for 10 years
Have you tried to upload it to the computer? Sometimes they get too much information on them and won't work. Are all of the connections to the batteries cleaned? Sometimes, also, there are bad connections between the machine and the batteries. Hope this helps.
3/17/2014 8:17:56 PM • LeapFrog... • Answered on Mar 17, 2014
LeapPad2 not recognise cartidge
My 2 yrs old froze her leopard 2 up . How do I get I to work again ?
1/10/2014 3:58:42 AM • LeapFrog... • Answered on Jan 10, 2014
2answers
How do you take apart a leapster learning game
My 2-year old appears to have broken the glass on her leapster. Is it beyond hope?
1/10/2014 3:57:48 AM • LeapFrog... • Answered on Jan 10, 2014
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
1/8/2014 10:39:37 PM • LeapFrog... • Answered on Jan 08, 2014
2answers
The touch screen does not work on leapster 2
Turn off the Leapster2 and remove cartridge (if there is one).
Push and hold down the hint button (the one with the question mark) while the game is off.
Turn the Leapster on while still holding down the hint button until you see the calibration screen.
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge. Login as usual.
If this does not work, then call customer service, depending on how old it is. I've had ours for over a year, and this still works each time.
1/5/2014 8:01:46 PM • LeapFrog... • Answered on Jan 05, 2014
Just got my daughter the Leap Pad 2 with rechargeable batteries, but never got to use it becuase the device never charged.
Did it come with the batteries installed or seperate? Make sure they work in another device after they charged for 24hrs. sometimes there is a seperator tap inside that needs to be pulled out chadman
12/24/2013 3:03:49 AM • LeapFrog... • Answered on Dec 24, 2013
Leapster explorer says memory full but it's not
1) Please run the LeapFrog Utility http://lfccontent.leapfrog.com/cs/utilities/LeapFrog_Connect_Utility.exe2) Select "Clear LeapFrog Connect User Data"3) Start the LeapFrog Connect application and wait until the message center indicates that all Leapster Explorer Updates have been downloaded.4) Power on and plug in your Leapster Explorer.
12/5/2013 3:36:31 PM • LeapFrog... • Answered on Dec 05, 2013
Can you download games to the sd card
open your leapfrog connect and plug in your device to ur pc. click on ur child's name. on the left at the bottom you'll see "on this device" click it, it'll show u a list of what's been bought/downloaded onto the leapster, you can fix it from there I had the same problem 2 weks ago and this is how I fixed it. and if it's not showing an app that you purchased at the very bottom there's a clicky "check for new dowloads" just in case... and here are 2 free codes for you: book 5813 1140 1518 1413 (might be 1314... sorry) game (alphabet stew) 5813 0709 4610 4973 hope they still work....
9/19/2013 6:16:24 PM • LeapFrog... • Answered on Sep 19, 2013
LeapFrog Leapster 2 Learning System Logo
Popular Tags
243 questions posted
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
View Most Popular
LeapFrog Toys
  • LeapFrog Toys
Most Popular Question
leapster gs touch screen won 39 t work
  • Toys
