20 Most Recent
Traxxas Stampede Monster Truck Rtrw/Xl 5 Questions & Answers
My RC Traxxas Stampede stopped working. The
what has happened is the brushes have lost contact with the shaft you need to clean them with some oil move the wheels back and forth with you hands after you added the oil to work it in use a very small screw driver to clean the shaft (past end) whale you are spinning the wjeels with you hands should work. I just performed that operation my self today. Same thing my xl5 steerinrg worked but no go............Good Luck,
Ez set button
The set button has a tendency to get stuck, try blow pressurised air around the button that might help. Else you have to disassemble the esc to get the dirt out, but you probably won't do that to a brand new esc.
Steering backward
Reverse steering channel on transmitter, there is a little switch for that.
My RC Traxxas Stampede stop working. The steering
Spin the rear wheels and make sure nothing such as a small stone is binding something up in the driveline. Check to make sure the motor has not gotten disconnected from the ESC. If you still have problems with it post again and I will try to look further into it.
The light, on the XL5
thats probably because you are using a nimh battery and lipo low voltage detection is off
