20 Most Recent Peg Perego John Deere Gator HPX Questions & Answers
the hood doesn't open on this toy but the front grill does flip down
Peg Perego John... | Answered on Aug 18, 2017
this toy doesn't have a valve
I f you are referring to the kids toy gator there is one nut on the front axle that can be loosened
wrong category, this is for the gator toys
What rack? There is no rack on the toy gator
wrong category this is for the toy gators
there is no fuse panel on this toy
just pull the red lever behind the seat
Peg Perego John... | Answered on Aug 17, 2017
could you please expand a little on when you say its broken? lots of these are assembled wrong with the rear black plastic pieces on backwards
Peg Perego John... | Answered on Aug 15, 2017
sounds like you have a bad motor, try disconnecting one of the motors and then try it again
the hood doesn't open, but the front grill does flip down
check the fuse on the battery
do you mean the shifter physically won't move into those positions, or once its in those positions it doesn't engage the motors
is there anything that is causing the wires to bind or come loose when its put back in
check the battery with a multimeter and verify that it is showing at least 12 volts, also shake the battery a little and if it sounds like there is sand in there then its dried up
probably a bad shifter switch you can order a new one here www.powerwheelsoutlet.com
Peg Perego John... | Answered on Apr 01, 2015
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Peg Perego John Deere Gator HPX Logo
160 questions posted
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
bought brand new gator
  • Toys
