20 Most Recent DLX 500 Remote Car Starter Questions & Answers
2answers
Bulldog Deluxe 500, remote not starting the the vehicle
Remove the battery in your remote for 15 sec, then put back in, start your car with your key, wait 15 sec, while the car is running press the * star button 2 times, it should beep , if not try it again, if still nothing post me back and we can go from there
12/4/2022 11:49:47 AM • DLX 500 Remote... • Answered on Dec 04, 2022
I have a Bulldog Model 500 remote started
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
1/23/2019 9:19:42 AM • DLX 500 Remote... • Answered on Jan 23, 2019
1999 Durango
try buuldog manufacturer on line help ,possibly needs programming via sequence on remote button
1/13/2014 8:00:17 AM • DLX 500 Remote... • Answered on Jan 13, 2014
Remot start wont start the car
are the battery in the key.fob.good ?
12/5/2013 7:22:01 PM • DLX 500 Remote... • Answered on Dec 05, 2013
Bulldog security 500d red light
I would first of all take apart and use an electricle spray to clean it ,,replace with new batteries, and you never know your look
10/31/2013 11:34:21 PM • DLX 500 Remote... • Answered on Oct 31, 2013
I have the Bulldog Security DLX 500 installed in an 05 Nissan Pat
What type of car is it installed in? The problem is most likely either that there is a factory anti-theft that you have not disabled, or there is a second or third ignition wire that is not connected. If you can give me the year-make and model I can give you a specific wire connection.
Thank you
1/24/2013 5:04:18 AM • DLX 500 Remote... • Answered on Jan 24, 2013
Bulldog Deluxe 500, cannot program the new remote transmitter.
Leave a comment if you need more help.Thanks for using Fixya.
10/16/2012 2:11:10 PM • DLX 500 Remote... • Answered on Oct 16, 2012
I just got a new
They generally dont need to be only if its not working.
2/3/2011 3:27:36 PM • DLX 500 Remote... • Answered on Feb 03, 2011
2answers
Bulldog Deluxe500 in '02 trailblazer will not start or reset.
unplug all harnesses going to unit for 5 min plug all harnesses back in and reprogram remote, you do not need to program for voltage sense, that is the factory defalt or call tech support at 1-800-878-8007
1/18/2010 4:43:38 AM • DLX 500 Remote... • Answered on Jan 18, 2010
Remote will not open doors, shows unlocked on
Try a fresh battery.
11/12/2009 2:56:04 PM • DLX 500 Remote... • Answered on Nov 12, 2009
Headlamps work all the time
pull the parking light fuse from the wire harness on the remote starter, it should be a blue 15amp not the green 30 amp, if that works you wired the parking light wire to the wrong one, if not post me and we will go from there
9/29/2009 3:50:42 AM • DLX 500 Remote... • Answered on Sep 29, 2009
Wiring diagram
9/29/2009 3:17:53 AM • DLX 500 Remote... • Answered on Sep 29, 2009
How do I start my car?
If you mean to keep the car running once it's already been driven, and you want to have it remain running, but take your keys with you, put the vehicle in park, release the brake, with the key in the "run" position, push the same button you use to remote start the car. You'll have the relays click, and the parklights (if connected) will come on. Don't touch the brake!! Turn key to "lock" position, remove key. Vehicle should remain running for the set amount of time like normal remote start operation. You may now lock your car with the remote, too. When you return to your car, turn key to "run" position, when you step on brake pedal, the remote start will cease operation, and you can drive car as if you had remote started car from a standstill.
6/4/2009 3:04:51 PM • DLX 500 Remote... • Answered on Jun 04, 2009
Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
3/29/2009 4:28:07 AM • DLX 500 Remote... • Answered on Mar 29, 2009
The unit just ticks when plugged in.
its a faulty unit. Had the same problem and brought the unit back for a new one and it worked perfectly and has ever since.
2/17/2009 2:54:31 AM • DLX 500 Remote... • Answered on Feb 17, 2009
DLX 500 Remote Car Starter Logo
Popular Tags
31 questions posted
Top Bulldog Security Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
John
John
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Bulldog Security Vehicle Parts & Accessories
Most Popular Question
just got new
  • Vehicle Parts & Accessories
