20 Most Recent On-Guard Alarm with Wireless Siren, Remote Keyless Entry, and Questions & Answers
Car alarm will arm but won't unarm
www.manualsonline.com/support-request.html i hope this helps good luck!
12/21/2013 3:59:19 AM • On-Guard Alarm... • Answered on Dec 21, 2013
Remote does not work change batters
Make sure you connect the batteries correctly, if it does not work then it can be due to an internal problem in the remote control... take it to the engineer..
9/23/2011 10:22:36 PM • On-Guard Alarm... • Answered on Sep 23, 2011
Battery died and I am having trouble getting my
if the remote keyless entry remote battery is totally lowbatt. open the remote and remove the battery, for emergency option, manually recharge it by contacting + and - terminal to charger or any source of dc voltage that compatible to your alarm battery, then assemble it again and try to operated on your lock unlock system
7/15/2010 8:40:03 PM • On-Guard Alarm... • Answered on Jul 15, 2010
I bought a 1992 honda
There are a couple things you can do. 1 is leave your key in the ON position (do not start) for EXACTLY 10 Minutes. Then try to start the car.
2. Disconnect the negative battery cable for 15 minutes, put back on and then try.
3. Pull the fuse on the alarm.
Find the alarm "brain" and disconnect it from the rest of the system. You'll probably need to rehook the starter wire to remove the relay that they would have included in the install.
The FIRST thing you should do is see if you have the "install guide" for the alarm. It should tell you what colours do what. MOST people put the "brains" close to the steering column. It may not even be mounted to anything, or may just be twistied to a wiring loom.
6/30/2010 3:46:49 PM • On-Guard Alarm... • Answered on Jun 30, 2010
What are the two side buttons for?
Depending on what vehicle it is installed in sometimes it will pen a trunk, gas door, or some other function. And sometimes, like in this case maybe nothing. Sorry I can't help you with much more than that. If you give me more information on the model of the alarm and the vehicle it is in, we can try to utilize these buttons if possible.
4/29/2010 9:11:04 PM • On-Guard Alarm... • Answered on Apr 29, 2010
MY CRIME STOPPER IS LOCKING AND UNLOCKING WHEN I
a connection may be faulty on your siren or car horn you can find the manuals at www.crimestopper.com under support then choose manuals and manuals again you have to use the model number from under your dash not the remote because they may be different if that does not work you can contact their tech support at 800.998.6880 ext 210
2/9/2010 7:43:55 PM • On-Guard Alarm... • Answered on Feb 09, 2010
Lossed the manual for the yale SAA5010 - PIR Siren with Keypad
Go to www2.yalelock.com/14711.epibrw
5/14/2009 7:22:26 PM • On-Guard Alarm... • Answered on May 14, 2009
Stuck in valet mode
To exit valet mode turn the ignition on and press the overide /program button for 4 to 5 seconds until the dash LED turns off and you hear the system chirp two times. That should get you out of valet mode. Please don't forget to rate. Thanks.
4/9/2009 1:52:10 PM • On-Guard Alarm... • Answered on Apr 09, 2009
Crimestopper SP502 usb remote wont hold charge
If your Crimestopper SP502 USB remote isn't holding a charge, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot and potentially resolve the problem:
  1. Check the Battery: Make sure the remote's battery isn't damaged or worn out. If the battery is old or not functioning properly, it might not hold a charge. If possible, replace the battery with a new one and see if the issue persists.
  2. Charging Cable and Port: Ensure that you are using a functional charging cable and connecting it to a working USB port. Sometimes, the issue might not be with the remote but with the charging equipment.
  3. Cleaning: Sometimes, debris or dirt can accumulate in the charging port of the remote, preventing a proper connection with the charging cable. Gently clean the charging port using a small brush or compressed air.
  4. Resetting the Remote: Try performing a soft reset on the remote. This might involve holding down certain buttons or combinations of buttons for a specific duration. Refer to the user manual for your Crimestopper SP502 for instructions on how to do this.
  5. Firmware Update: Check if there's a firmware update available for your remote. Sometimes, firmware updates can improve the device's performance and battery life.
  6. Contact Customer Support: If none of the above steps work, consider reaching out to Crimestopper's customer support for assistance. They might be able to provide further troubleshooting steps or suggest a solution.
  7. Battery Calibration: In some cases, calibrating the battery can help improve its performance. Fully charge the remote, then use it until the battery is completely drained. Repeat this process a couple of times to see if it helps the battery hold a charge better.
  8. Replace the Remote: If the remote is still not holding a charge after trying the above steps, it's possible that there's an internal hardware issue. In this case, you might need to consider replacing the remote.
Remember that the specific steps you should take may vary depending on the model of your Crimestopper SP502 remote and the instructions provided in its user manual. If you're uncertain about any step, it's a good idea to refer to the manual or seek assistance from the manufacturer's customer support.
8/9/2023 10:19:22 AM • Crime Stopper... • Answered on Aug 09, 2023
I need a video or wiring diagram for a Crime Stopper Cool Start RS4-G5 wired to 2007 Chevy Equinox please.
Question edited to add a few capital letters. Videos and instructions in the link https://www.google.com/search?q=crime+stopper+cool+start+Rs4-g5 ..
7/16/2022 9:08:10 PM • Crime Stopper... • Answered on Jul 16, 2022
Vehicle wont start with sp101 alarm
under the dash by the steering column you will see some wires that dont belong and a small black box about a inch square two wires will go up and into the steering column there will only be two that come from the box cut the wires that go to the box and connect them together its the starter disable . removing the blk box it should start
2/3/2019 9:08:59 AM • Crime Stopper... • Answered on Feb 03, 2019
I purchased a crime stopper remote starter for a 2003 mazda6 with bypass. I have it installed but cannot program the bypass any tips or suggestions on what I am doing wrong??
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u .. U can also get free manuals
1/29/2019 8:27:50 AM • Crime Stopper... • Answered on Jan 29, 2019
How program crime stopper remote control # CHX433TX of 6 buttons
1/29/2019 8:18:48 AM • Crime Stopper... • Answered on Jan 29, 2019
My crime stopper remote start only clicks. When I take it to the shop it only takes like 1 minute to fix.. What do you think they do?
why don't u try online websites.. some websites deal in it real time.. along with solutions to problems how to repair fix service nd all let me know if u need help I know plenty
1/28/2019 10:10:49 AM • Crime Stopper... • Answered on Jan 28, 2019
On-Guard Alarm with Wireless Siren, Remote Keyless Entry, and Logo
26 questions posted
Top Crime Stopper Vehicle Parts & Accessories Experts
John
John
ADMIN Andrew
ADMIN Andrew
oneStan
oneStan
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Crime Stopper Vehicle Parts & Accessories
Most Popular Question
lossed manual yale saa5010 pir siren
  • Vehicle Parts & Accessories
