20 Most Recent Remote Starter with Keyless Entry Questions & Answers
it's obvious, you don't have it wired up corectly either via grounding or via power suppply. it's blowing the fuses because you're prboably pulling too much amperage. you'll need a multimeter to see what levels of voltage and amperage and resistance are registering.
Remote Starter... | Answered on Jun 06, 2019
I take help from online websites that have this service like helping in repair some like reliable-store h ave instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Remote Starter... | Answered on Jan 29, 2019
hey larry wrong site this is fixya need to send your gripe to the correct party
Remote Starter... | Answered on Nov 08, 2017
This is not really a question ...
Remote Starter... | Answered on Feb 03, 2015
Replace battery?
Remote Starter... | Answered on Dec 26, 2013
Yes, There are two Immobilizer bypass modules on the market that will work with your vehicle without having to sacrifice a key. Xpresskit offers the DBALL and PK9. Both require programming to function properly.
Remote Starter... | Answered on Nov 22, 2013
connect the yellow wire to the gm's vatts passlock 1 and passlock 2 + positive wire
Remote Starter... | Answered on Nov 21, 2013
yr best bet would go to there web site and look for the system that is installed in your vehicle, bulldog.com and look at the drop down, it tells you what is needed to work your system.
Remote Starter... | Answered on Nov 04, 2013
remove the bulldog and mount it again, in another car. see if it does the same.
they lock in sometime. the park saftey switch is most likely to blame. pull it out of park and put it back in a couple ot times with the motor off but ignition on. bmw does it to.
Remote Starter... | Answered on Sep 27, 2013
Okay?!
Remote Starter... | Answered on Jan 21, 2013
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
Remote Starter... | Answered on Jan 16, 2013
The yellow wire at the ignition switch is not connected to the remote start system. Once it is connected to the accessory output of the remote start, it should work properly.
Remote Starter with Keyless Entry Logo
129 questions posted
Top Bulldog Security Vehicle Parts & Accessories Experts
Larry Tezekjian
Larry Tezekjian
Matthew Boulden
SSN-MM3
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Bulldog Security Vehicle Parts & Accessories
Most Popular Question
transponder 2006 mitsubishi eclipse
  • Vehicle Parts & Accessories
