20 Most Recent
Lemond Revmaster Revolution Trainer Questions & Answers
How to adjust the seat on an indoor cycle
Video of How to Adjust the Seat on your Indoor Cycle
- This video will demonstrate how to adjust the seat on your indoor cycle properly
- Tools needed:
- To begin loosen the nuts on each side of the seat equal turns
- Ideally, there should be equal portions of the clamp bolt exposed on each side
- Once you have them loose you can adjust the seat back and forth on the mounting rails as well as adjusting the angle of the set
- The best position for the seat is level and in the center of the mounting rails adjustment
- Once you have the seat positioned as desired finger tighten the nuts on each side of the seat equal turns and then tighten the nuts using a wrench an equal number of turns as well
- Again, the goal is to have equal portions of the seat clamp bolt exposed on each side
- This is all that is required to adjust the seat on your indoor cycle.
Olympus Sport exercise bike, model OS-11202. Resistance braking (gear/level change) is not working.
1. CHECK THE RESISTANCE KNOB: MAKE SURE IT'S NOT STUCK OR DAMAGED. TRY TURNING IT TO SEE IF IT ADJUSTS THE RESISTANCE.
2. INSPECT THE RESISTANCE MOTOR: SOMETIMES THE MOTOR THAT CONTROLS THE RESISTANCE MAY BE MALFUNCTIONING. CHECK FOR ANY SIGNS OF DAMAGE OR WEAR.
3. RESET THE BIKE: TURN OFF THE BIKE, UNPLUG IT, WAIT FOR A FEW MINUTES, THEN PLUG IT BACK IN. THIS MAY RESET THE SYSTEM AND FIX THE ISSUE.
4. CONTACT CUSTOMER SUPPORT: IF NONE OF THE ABOVE STEPS WORK, IT'S BEST TO CONTACT OLYMPUS SPORT CUSTOMER SUPPORT FOR FURTHER ASSISTANCE.
Screws of fitbit charge HR not coming out using a replacement band screwdiver kit
- Verify the compatibility: Ensure that the replacement band screwdriver kit you are using is specifically designed for the Fitbit Charge HR. Different devices may have varying screw sizes or types, so it's important to use the correct tool for your specific Fitbit model.
- Apply proper pressure and technique: When using the screwdriver, make sure you are applying sufficient downward pressure while turning it counterclockwise (lefty-loosey) to loosen the screws. Use a steady and firm grip, but be cautious not to apply excessive force that could potentially damage the screws or the device.
- Check the screwdriver tip: Ensure that the screwdriver tip is appropriately sized and fits securely into the screw head. If the tip is too small or too large, it may not engage properly, making it difficult to loosen the screws. Try using a different screwdriver tip from your kit or consider obtaining a compatible screwdriver specifically designed for the Fitbit Charge HR.
- Apply lubricant (if necessary): If the screws are stuck or resistant, you can try applying a small amount of lubricant, such as WD-40 or a light machine oil, to the screw threads. This can help loosen any corrosion or debris that might be hindering the screw's movement. Allow the lubricant to penetrate for a few minutes before attempting to unscrew again.
Machine not running but lights coming on ok. There was a noise before this happened. Would it be the motor
To further troubleshoot and confirm if the motor is indeed the issue, you can try the following steps:
- Power off and unplug the machine: Turn off the machine and unplug it from the power source to ensure your safety while performing any inspection or maintenance.
- Check for visible damage: Carefully inspect the motor for any visible signs of damage, such as loose wires, broken parts, or burnt or melted components. If you notice any visible issues, it may indicate a motor problem.
- Test the motor with a multimeter: If you have access to a multimeter, you can test the motor's electrical continuity and resistance. This can help determine if the motor is functioning properly or if there are any electrical issues.
- Listen for abnormal sounds: While the machine is unplugged, manually rotate the elliptical pedals or try to move the flywheel. Listen for any unusual or grinding sounds that could indicate a motor problem.
- Contact NordicTrack customer support: If you are unable to pinpoint the issue or if the motor appears to be faulty, it is recommended to contact NordicTrack customer support or consult a professional technician. They can provide guidance, diagnose the problem accurately, and assist you with repair or replacement options.
Nordic Track 1300 commercial elliptical. Why can't I level up the resistance?
If you are unable to increase the resistance on your NordicTrack 1300 Commercial elliptical, there could be a few possible reasons for this issue:
- Incorrect operation: Ensure that you are following the correct procedure to adjust the resistance. Refer to the user manual or instructions provided by NordicTrack to ensure you are using the correct buttons or controls to increase the resistance. Sometimes, there may be specific steps or requirements for adjusting the resistance level.
- Mechanical issue: There might be a mechanical problem with the resistance mechanism. Check if the adjustment knob or lever is functioning properly and not stuck or damaged. Inspect the cables or belts connected to the resistance system to ensure they are intact and properly connected.
- Electronic issue: The resistance adjustment on some ellipticals is electronically controlled. If the console or control panel is not working correctly, it may affect your ability to adjust the resistance. Check if any error messages are displayed on the console or if there are any other issues with the electronic components.
- Calibration required: In some cases, the elliptical may need to be calibrated to ensure the resistance levels are accurate. Consult the user manual for instructions on how to calibrate the elliptical or contact NordicTrack customer support for guidance.
- Malfunctioning parts: There could be a malfunction or failure of specific components related to the resistance system, such as the resistance motor or sensors. If you have ruled out other possible causes, it may be necessary to have a professional technician inspect and repair the elliptical.
What is the maintenance required for folding exercise bikes?
Cleaning: Regularly wipe down the frame, seat, pedals, and any other accessible surfaces with a damp cloth to remove sweat, dust, and debris. Avoid using harsh chemicals that may damage the bike's finish.
Lubrication: Apply lubricant to the moving parts such as the hinges, pedals, and resistance mechanism according to the manufacturer's recommendations. This helps prevent rust and ensures smooth operation.
Tightening: Periodically check and tighten all bolts, screws, and nuts to prevent loosening during use. Pay particular attention to the folding mechanism to ensure it remains secure.
Inspecting: Examine the bike for any signs of wear or damage, such as frayed cables, worn pedals, or loose components. Address any issues promptly to prevent further damage and ensure safety.
Storage: When not in use, fold the bike properly and store it in a clean, dry area away from moisture and direct sunlight. This helps prolong its lifespan and prevents corrosion.
Battery maintenance: If your folding exercise bike includes electronic components such as a display console, ensure that the batteries are replaced as needed to maintain proper functionality.
Regular servicing: Consider scheduling periodic maintenance checks with a professional technician to ensure all components are in good working condition and to address any potential issues before they escalate.
Promaster pro plus 2 error code 31
Error 31 on your Promaster Pro Plus 2 treadmill could indicate a variety of issues, such as a problem with the motor or the motor controller. Here are a few troubleshooting steps you can try:
- Power cycle the treadmill: Turn off the treadmill and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. Sometimes, simply resetting the treadmill can resolve error codes like Error 31.
- Check the motor connections: Make sure all the wires and connections to the treadmill motor are secure and properly connected. Loose connections could cause error codes to appear.
- Inspect the motor controller: The motor controller regulates the speed and operation of the treadmill motor. Check for any visible signs of damage or overheating on the motor controller. If you notice any issues, you may need to replace the motor controller.
- Contact customer support: If you're unable to resolve the issue on your own, it's best to contact the manufacturer's customer support for assistance. They can provide specific troubleshooting steps for your treadmill model and may be able to offer a solution or arrange for repairs if necessary.
By following these steps, you can hopefully resolve Error 31 on your Promaster Pro Plus 2 treadmill and get it working again.
Treadclimber TC 200 treadles rubbing in the middle
Check Alignment:
First, ensure that the treadles are properly aligned. Misalignment can cause rubbing. Make sure the treadles are parallel to each other and evenly spaced.
Tighten any loose bolts or nuts that secure the treadles to the frame.
Inspect the Walking Belt:
Examine the walking belt for any signs of wear, fraying, or damage. A damaged belt can cause uneven movement and rubbing.
If the belt is worn out, consider replacing it.
Lubricate the Bolts and Joints:
Apply lubricant (such as silicone spray) to the bolts and joints where the treadles connect to the frame. This can reduce friction and prevent rubbing.
Be cautious not to over-lubricate, as excess lubricant can attract dust and debris.
Check for Obstructions:
Look for any foreign objects (dirt, debris, or small items) that might be caught between the treadles or near the alignment bolts.
Remove any obstructions to ensure smooth movement.
Inspect the Alignment Bolts:
Make sure the alignment bolts are properly adjusted. They should be tightened enough to prevent excessive movement but not too tight to cause rubbing.
Adjust the bolts if necessary.'
Test the TreadClimber:
After performing the above steps, test the TreadClimber to see if the rubbing issue persists.
If the problem continues, consider contacting the manufacturer or a professional technician for further assistance.
