20 Most Recent
Black & Decker DEWALT 12 In. 80 Tooth Thin Kerf Saw Blade Questions & Answers
Table saw blade wabbles alot when cutting?
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
How do i replace the grinder wheel on a skil 9310?
You need a special wrench that has two notches on the end. Make sure the item is unplugged. Place the wrench on the two holes where the wheel is. There is a button on top not the on off switch. The button over the wheel it's self. Push this button in as it locks the wheel. Turn the wrench counter clock wise to remove ring. Remove and replace wheel. Put on ring and do the opposite. Hold down the button and turn the wrench clock wise. That's it. Let me know if I can help you with anything else.
JimmyC
My 3051 worm drive circular saw has he bade
Just for your information there are not many parts available for this model any longer.
With that said, it may be something rather simple. I get this type of problem all the time. Does the blade have the diamond punchout still in the blade or has it been punched out? Make sure that the the type of mount is the same as the hole for the blade. Another thing to check is to make sure the clamp washer is there under the blade. This is the part that will have a raised lip that goes through the hole in the blade just enough to center it. If that is missing you can replace it with a new one: part #
143783-00 . If those 2 solutions do not work, it is your main drive gear. The worm is probably ok but the gear is probably shredded. This part is unavailable and renders your saw useless.
Motor runs backwards
Has it been this way since new? Return for replacement. Has someone opened it up and messed with the insides? Wiring crossed.
Owners manuals
I would like to get the instruction manual for a black & decker orbital jigsaw model JS400. I the hose fiiting for the shop vac, also the guide for the wood. thank you skip
