20 Most Recent Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Questions & Answers
Hi i need hiliti TE22 switch
Any one can help me
Hilti Hammer... | Answered on Nov 27, 2019
THE TOOL IS LOW ON OIL. OR POSSILBE SEAL ISSUE, IT TAKES ITS OWN OIL, HAVE TO GET IT FROM HILTI!!! BE PREPARED YOU HAVE TO BUY A GALLON AT A TIME! IT HURTS!!! OR YOU CAN SEND IT TO HILTI AND YES THEY WILL BE MORE THAN HAPPY TO FIX IT FOR YOU OR GIVE YOU CREDIT TOWARD A NEW ONE, THATS HOW THEY WORK!
Hilti Hammer... | Answered on Oct 09, 2019
stare switch not working...Replace it
Hilti Hammer... | Answered on May 13, 2019
Did you contact the place you purchased it from? If you still have the paperwork that came with it might have the replacement part #s in one of the flyers. Google the make and model.
Hilti Hammer... | Answered on Aug 04, 2014
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Hilti Hammer... | Answered on Aug 09, 2013
Contact Hilti @ 1-800-879-8000
If they don't have one for the 800 the 805 shares some of the parts
Hilti Hammer... | Answered on Mar 08, 2013
Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Logo
46 questions posted
Top Hilti Drills Experts
John Trevino
Marvin
Marvin
Vincent G
Vincent G
Are you a Hilti Drill Expert? Answer questions, earn points and help others
View Most Popular
Hilti Drills
  • Hilti Drills
Most Popular Question
need buy rotor hilti t e 2 not
  • Drills
