20 Most Recent
Sierra Online, Inc. Half-Life: Counter-Strike for Windows Questions & Answers
I cant find downloaded counter
If you are using steam and you need to open it to play it, just open steam and go to libraryand click Counter Strike and hit Play.
If you want to navigate to the page it's in either program files/steam/steamapps/(steamusername)
or files/steam/steamapps/common
If you installed it from disk it would be under program files/sierra
If you illegally pirated it it's probably waiting in your downloads folder to be installed
Counter-strike 1.6
see if your mouse has left hand properties
control panel set up mouse OR
If you cannot switch your weapon to the right-hand, please go to your advanced video options and change the renderer to either
OpenGL or
Direct3D. The software renderer does not support right-handed models.
You can select left or right-handed models by typing the following command into the
Console:
- To use your left-hand: cl_righthand 0
- To use your right-hand: cl_righthand 1
You may wish to create a
userconfig.cfg file with the cl_righthand 0 command if you would like to keep the left-handed setting. Please follow these instructions to create a user.cfg file:
- Locate the subfolder in your game folder that holds the config.cfg file
For example, you can find the config.cfg file for Counter-Strike at [Steam installation directory]\steamapps\[your Steam account name]\counter-strike\cstrike\config.cfg
- Create a new text file in that directory called userconfig.cfg
- Open the file with Notepad and enter cl_righthand 1 (to use the right-handed model) or cl_righthand 0 (to use the left-handed model)
- Save the file
- Launch the game to test the user.cfg settings
NOT COMPLETED INSTALLING
Nowadays, everything hs to be done with steam if you want to play Valve videogames.
To do so, goto: http://store.steampowered.com/ and click on the install button (top right corner).
Once you have steam installed, you will be able to activate your Counter-Strike directly with your serial key. It will then download + install itself automatically, without the need for CDs.
There you go!
I want download a counter
try searching torrents.Open google.comcopy and paste the following query:filetype:torrent counter strike 1.6have fun download software like uTorrent or opera browser to download torrent files
Conter strike
Try to uninstall and reinstall your game by going to your control panel in your start menu. Sometimes the game can be installed incorrectly and cause issues with online play.
Hopefully this will solve your issue
How to download counter strike
You can download Counter Strike for PC via Steam.
You will need to sign up for a steam account before you can purchase.
Link to the game:
http://store.steampowered.com/app/10/
I have installed the game(counter-strike)
first off all if you want to play through internet then put firewall off.. After that try to make game your own. then wait for players.. After that refresh list and players will come online. Then play,,
enjoy..
