20 Most Recent
Kyocera FS-1118MFP Laser Printer Questions & Answers
Fs-1118mfp firmware
Where can I find the firmware to kyocera FS-1118MFP?I have the Compact Flash and I need the files. There is files in https://www.kyoceradocumentsolutions.es/es/support/downloads.name-L2VzL2VzL21mcC9GUzExMThNRlA=.html#tab=application but not firmware, only .BIN filesDrivers, fonts and docs in http://www.opendrivers.com/modeldriver/kyocera_fs-1118mfp-driver-download.htmlDrivers in http://www.opendrivers.com/modeldriver/kyocera_fs-1118mfp-driver-download.htmlError code list in https://printcopy.info/?mod=erc&brand=Kyocera&model=FS1118MFPSOLVED. The firmware can be downloaded from https://www.elektroda.pl/rtvforum/topic2733888.html#19175098or in the canal https://t.me/kyoceraFS1118MFP
1/9/2022 12:08:26 AM •
Kyocera...
Answered
on Jan 09, 2022
Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
4/10/2019 3:32:28 AM •
Kyocera...
Answered
on Apr 10, 2019
I have a fs c2126
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
11/17/2017 9:03:02 AM •
Kyocera...
Answered
on Nov 17, 2017
Can this be set-up wireless, and if so how ?
no it can't however it should have a 10/100Base-TX ethernet port. You should be able to plug it into a Wireless Router and be able to access it via an ethernet ip network. However you would have to set the laser fs-1118mfp printer to an appropiate IP address and subnet mask and set the router to issue DCHP to Ip addresses outside the printer range of IP addresses. So for example 192.168.0.1 router 192.168.0.2 could be assigned to printer and DHCP leases assigned to 192.168.0.10 - 192.168.0.254 using a subnet mask of 255.255.255.0 for all the ip addresses. The router could communicate with laptops via wireless but each laptop would need the laptop operating system driver for the printer added and the ip address would be 192.168.0.2 for the printer. it could also be done on 10.0.0.whatever 10.0.0.1 router 10.0.0.2 printer 10.0.0.10 -10.0.0.254 DHCP server leases. If you have a ethernet network already you could just add a wireless access point to the network .
10/9/2015 1:02:15 PM •
Kyocera...
Answered
on Oct 09, 2015
How do I unlock my printer a Kyocera fs 1118mfp when error C6000 appears?
Press the system menu/counter key,Select Service setting using the up/down cursor keys.While pressing the start key and the # key, press the enter key.then select 163 Resetting the fusing problem data Description Resets the detection of a service call code indicating a problem in the fusing section. When a service call concerning the fusing section occurs, turn the power switch off and open the front cover. Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode. Purpose To prevent accidents due to an abnormally high fusing temperature. Method 1. Press the enter key. A selection item appears. 2. Select Execute using the up/down cursor keys. 3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.) Completion Press the back key. The indication for selecting a maintenance item No. appears.
6/28/2015 12:19:21 AM •
Kyocera...
Answered
on Jun 28, 2015
I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
12/11/2014 8:08:56 AM •
Kyocera...
Answered
on Dec 11, 2014
When i send to e-mail
3101: SMTP Authentication error. Consult with Your network
administrator to verify that your Login Account, Name and
Login Paswrod required for SMTP Authentication are correct.
12/5/2014 8:47:21 AM •
Kyocera...
Answered
on Dec 05, 2014
Kyocera FS 1128mfp error code CF248 - what does this mean?
corrupt print data.
set the driver back to KPDL, make sure to uncheck the "allow data pass through" in the settings area, this makes a world of difference and ends up eliminating alot of print errors. It's been talked about in other threads on this site. I've talked to KM tech support about this setting and they don't really know what it is for
9/28/2014 7:23:12 AM •
Kyocera...
Answered
on Sep 28, 2014
What is Toner Cover and how can open
Usually when we say toner cover, we mean the top cover, which is the cover we open to change the toner kit (catridge).
The error C-6000 refers to the fuser unit. You have to remove the fuser unit and check if the heater lamp and/or the thermistor and/or the thermostat are damaged.
9/28/2014 7:03:45 AM •
Kyocera...
Answered
on Sep 28, 2014
