20 Most Recent
Freud FT2000E 3 Router Questions & Answers
Freud ft2000e speed control dosen't work. what
Good day My name is Larry Boccioletti I am a freud auth service station in Canada.I have or can get through the factory in ontairo almost any freud part you need.I ship most times same day as long as there are no back orders.Please allow me to help in anyway I can.Thanks LarryHalton Maint Centre Milton Ont,Canada
[email protected] or 905 876 9981
I,AM LOOKING FOR A POWER SWITCH FOR MY 2000E
You can order your switch from Freud at (800) 334-4107. It is number 42 on the parts breakdown which you access at: http://www.freudtools.com/images/manuals/FT2000VCE.pdf
Freud's part number is 76325.7001
It doesn't seem like anyone stocks Freud parts. Went to some discussion sites and found that even repair centers don't stock them. You'll have to contact them directly.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
How do I remove the base of a Freud FT2000e router
Hi There, My name is Larry --I am a FREUD DEALER IN CANADA
To answer your question about the router springs.You must first remove the cap carefully to prevent any damage to the speed module. Under the cap you will find two nuts first lock the base and leave about 2 inches for a socket to go over the nut .Remove normally and be careful when you release the base do it slowly it will spring up fast and hard --
I have a fe-2000 router in the middle of a project...
Hello Mr INDIANA,
My name is Larry Boccioletti and I am the last remaining dealer in Ontario Canada.I have the parts
.My company is Halton Maintenance Centre
my email is
[email protected]
Freud has been bought out by Bosch and their tools are being fazed out.
I think your speed control module went on the fritz not your switch.
The speed module is still available and the switch to.
If you would like a quote I would be happy to oblige all I need is the colour of the cap,the serial number and make sure of the model.
Thanks Larry
Suddenly slowed down and speed can not be
Hi There my name is Larry Boccioletti from Ontario Canada.
I am a Freud service dealer.
Your problem is in the speed control module located under the cap.
Because it is a sealed unit it is not repairable.
But they are replaceable.If you can let me know the colour of the cap I will let you know which one you need.
They made some changes so the colour is important.
and my email is
[email protected].
If you like I can send you a quote.
Thanks
Larry
Replace brushes in a ft 2000 vce 1900 watt motor
Hello Thomas,
My name is Larry Boccioletti from Ontario Canada.
I am a service and parts dealer for Freud.
If you are looking for parts to repair an FT2000 or FT3000
I have them carbon brushes,brush holders,almost anything.
I would be happy to send a quote if you like.
My company is Halton Maintenance Centre and my email is
[email protected]
Thanks
Larry
Ft2000E router switch
Hi There I am a Freud dealer in Canada I have switches in stock.
If you wish a quote just send me an email request and I will be happy to.
My Name is Larry Boccioletti and my companies name is Halton Maintenance Centre and my email is
[email protected]
Larry
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Freud FT2000E Brushes
You have a couple options, I found a website for Freudtools.com where you can find a dealer near you or you can call Freud direct at 1-800-334-4107 to order the brushes. The part number I saw that you need is 13413.9073 but you might want to double check me on that . let me know if I can help further
