20 Most Recent
Schlage FE595-CAM-ACC FE595-CAM-716-ACC Aged Bronze Electronic Security Key Questions & Answers
I am looking for the
This link will take you to the page you need, to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Entry Flex-Lock...There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/10/2011 3:00:49 AM •
Schlage...
Answered
on Nov 10, 2011
Schlage FE 595 - -
This link will take you to the page you need, to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security.....There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/9/2011 2:19:56 AM •
Schlage...
Answered
on Nov 09, 2011
I lost the manual for
Go to this page for downloadable instructions and videos:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxA note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/Good luck!
11/8/2011 7:04:35 PM •
Schlage...
Answered
on Nov 08, 2011
I just installed last week
Assuming you've followed the installation directions accurately and do not have a mechanical bind within the lock or between the lock and strike plate (how does it operate when cycled with the door open?). Beyond that, I'd exchange the lock with a new one.
On this page you will find videos of how to install and how to program your lock:
If all else fails, here is a link to the customer service contact page:
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
5/9/2011 1:09:18 AM •
Schlage...
Answered
on May 09, 2011
I need to know if a Schlage be365 deadbolt 5 pin cylinder can be replaced with a 6 pin cylinder
I don't know if the deadbolt is the same as the BE-series lever-handle lock that I worked on, so this answer is about the lever-handle one:I just had that same problem last week! The short answer is, "No, you can't replace the cylinder," but if you are willing to do some surgery on the lock and take it apart (take a picture just before you remove each piece!), you can put a tiny opening on the cam on the back of the cylinder so a 6-pin key can go all the way into the cylinder and then go through the back. The cam comes off in a unique way: depress the tiny brass dot in it and then turn it about 1/4 turn (maybe a little more or less, I don't remember exactly) and it will come off. You can then rekey the cylinder to your key and, as I said, make that little hole in the cam. To make the hole, I used a Dremel rotary tool with a 1/16" diameter bit. To figure out exactly where to make the hole, I put some lipstick on the end of my key and pushed it all the way into the keyway before I took the cam off. (You could achieve the same thing by sharpening a straight piece of piano wire or spring steel wire, pushing it through to the back of the keyway and wiggling it a lot to make scratch marks.) Keep your hole as small as possible so you don't weaken the cam. Assemble everything back together and you can now use your 6-pin key.I'm being a little flippant here. The mechanism inside that lock is pretty complicated. I'm a locksmith with over 40 years experience, and while it took me only a few minutes to make that hole and rekey the cylinder, it took me about an hour to figure out how all the pieces that connected to the motor fit back into the case so they would allow the outside handle to engage the lock when the motor activated, how the wires needed to be put back in around the edges and not bind against anything, and finally to get the cover back on. Good luck!
