Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
I bought the safe executive CS-2 less than a year ago,
Couple of month ago started to hear beep all the time with ready led switched on, I thought it might be the batteries, I changed them but same problem, I thought maybe it needs new code, I changed it but still the same?
I appreciate your feed back
Thanks
Mohamed
To unlock a high security safe without breaking its integrity will be a tough job for you but i guess the following link may provide you with some assistance:http://www.youtube.com/user/harisonkeys?feature=mhee
The Stramm safe we have is a small one that we use to store keys for our drivers. To change the combination, open the safe with the current combination. Sorry, can't help you if you don't know that. Inside the door is a plastic panel covering the batteries. Pinch the plastic catch at the top and open the panel. There is a small red button which you can press to change the combination. When you press it, you will hear a double beep. Enter your desired new combination. The trick is that the last digit must be either an "A" or a "B" which signals the end of your combination. For example, if you want your new combination to be 123456, you can't do that. The closest you can come is 123456A or 123456B. Hope this helps. Steve, Mbeya, Tanzania
Hi there all I have a SURESAFE electronic security safe MODEL-OWSAFE30ES (1) To set your own code first on safe(2) locate the red reset button on the hinge end of the door.(3) Press the red button, which will illuminate the yellow light on the keypad.(4) Now key in your new code (3 to 8 digits) and press A or B to end. Note you have 30 second to complete this step.(5) Test your new code whilst the door is open. Safe will beep twice to confirm code has been entered correctly, and knob can be turned clockwise.(6) Repeat process any time you wish to change your code.,Hope this help regards rick
1) look again for the key
2) call a lock smith
3) drill the lock
these safes arent expensive , cheaper to drill the lock and replace that a lock smith , but get a quote
Put the safe on your lap and bounce it on your knees and keep tying to turn the knob I had it opened in less then 10 seconds! And the batteries were dead this really does work.
