20 Most Recent
Miller Spectrum 375 X Treme Plasma Cutter 907339 Questions & Answers
Miller 375 x-treme fires about 30 seconds then stops it doesn't stay running, no trouble lights...
Have you watched to see if the pressure light comes on right before shutdown? If so you may need to add a tank right next to the torch base to address the pressure drop assuming your air source is able to deliver adequate volume to the cutter continuously and you currently have more than 25 feet of hose between cutter and compressor. It might not hurt to check the internal filter as well.
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
I have a Miller Synco Wave 350 DX TIG/arc welder but my Remote 14 is not reading my pedal. I checked the pedal and its good. I turned welder off unplugged the pedal, turned welder back on.
Based on the information provided, it seems that there may be an issue with the Remote 14 connection on the Miller Synco Wave 350 DX TIG/arc welder. Here are some steps that can be taken to troubleshoot the issue:
1. Check the Remote 14 connection: Make sure that the Remote 14 connector is securely plugged into the welder. If it is loose or not fully connected, this could cause issues with the pedal not being recognized.
2. Check the pedal connection: Ensure that the pedal is properly connected to the Remote 14 connector. If it is not plugged in all the way or if there is any damage to the cable, this could cause issues with the pedal not being recognized.
3. Check for error codes: The Miller Synco Wave 350 DX TIG/arc welder has a built-in diagnostic system that can display error codes if there is an issue with the machine. Check to see if any error codes are displayed and refer to the user manual for troubleshooting steps.
4. Contact Miller customer support: If none of these steps resolve the issue, it may be necessary to contact Miller customer support for further assistance.
In summary, if your Remote 14 is not reading your pedal on your Miller Synco Wave 350 DX TIG/arc welder, you should check the connections, look for error codes, and contact customer support if necessary.
