20 Most Recent
Easton Synergy Cnt Softball Bat Questions & Answers
Loose end cap
Boil some water in a pot and hold the barrel in the water for 2-3 mintues to soften the end cap so you can remove it. Once removed, sand down the inside of the barrel and the male side of the end cap to remove any manufacturer glue residue. Use a 2 Part Marine Grade Epoxy and apply to both ends. Set the bad down barrel side down for at least a week and you should be good to go. The longer the cure time, the better. Marine Grade Epoxy is gives a stronger bond and is impact resistant. You can go with a Devcon 2 part epoxy but the Marine Grade is better
Easton synergy softball bat
clean the end of bat get some j b weld at a hardware store mix it up ,put on cap evenly put cap back on bat let it sit for 24 hrs.
I have a 7 ft
here are the visual instructions to assemble it. have a look to see if there is a part used during assembly that is still attached to the frame.
