20 Most Recent Bowflex Revolution Home Gym Questions & Answers
The original assembly manual is available directly from the manufacturer at bowflexcatalog.com, there is a product manual link near the bottom of the page.
Bowflex... | Answered on Nov 25, 2014
There is a pop pin on the support at the end of the seat rail that must be pulled out to fold a Revolution up. You might want to download the complete operation manual, it is available directly from the manufacturer at bowflexcatalog.com. The product manual link is at the bottom of the page.
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Bowflex... | Answered on Jul 02, 2014
I have the same gym plus the assembly instructions in PDF format. I don't seem to find an upload button for the PDF file. If you email me at nouse65@gmail.com I can send it over to you.
Bowflex... | Answered on Feb 09, 2013
I am having the same problem with the right pully. How did you fix yours?
Bowflex... | Answered on Jul 05, 2012
Bowflex Revolution Home Gym Logo
64 questions posted
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Bowflex Sport & Outdoor - Others
Most Popular Question
need assebly manual bowflex xtl
  • Sport & Outdoor - Others
