20 Most Recent Fuji Rod Repair Kit Questions & Answers
I have a fuji xp60. Just charged the battery.
I had a Fuji camera which did similar. It turned out to be a defective component inside the camera. Fuji do a repair service where you contact them for an estimate before repair. If the camera is old, it may not be worth the cost and cheaper to buy a later model. Sorry
2/9/2018 2:20:38 PM • Fuji Rod Repair... • Answered on Feb 09, 2018
Have had a fujifilm finepix
If you have a power adapter for it try to see if it will power up using that. If it does install fresh batts and see if that will work. I use rechargeable batts with mine and have allowed them to fully discharged at times for up to a month. I pop in fresh batts and it always fire up for me.
10/2/2017 6:19:07 PM • Fuji Rod Repair... • Answered on Oct 02, 2017
I some how screwed up
Unless you post the make and model of the camera in the comments below all we here can do is give you generic answers like return the exposure compensation settings to zero set the dial to shutter priority and set a fast speed but the faster the shutter the more light you need to get the correct exposure so at night you need to use a very fast lens about F2.8 or better still F1.4 and a powerful flashgun to freeze the action along with an high ISO speed or learn to pan while shooting at least with a digital camera you won't be wasting lots of film getting the technique right
5/13/2017 11:43:25 AM • Fuji Rod Repair... • Answered on May 13, 2017
Manual for JV110 Fujifilm digital camera
When you go to this site link,below, you will see a search box on the right of the page. In there put "JV110 Manual" without the quotes, then you can print out as a booklet, if your printer has this capability. http://www.fujifilm.com/support/.../manuals/.../finepix_jx200_manual_01.pdf
8/31/2014 9:13:47 AM • Fuji Rod Repair... • Answered on Aug 31, 2014
2answers
I ACCIDENTLY ERASED PICTURES AND A VIDEO FROM MY
Yes you can un-erase the files even u have formatted the disk. but you should not fill the space, i mean before recovering u should not take any photos or videos.. once u recovered ur files... then u can use asusual.. use this tool to recover ur files.. Kernel for FAT Plus NTFS v4.03
for any further clarifications... buzz me...
bye
- Rajkumar
9/4/2013 3:42:37 AM • Fuji Rod Repair... • Answered on Sep 04, 2013
After taking photo the picture is very white as if overexposed got it secondhand and not sure of settings
Try changing your settings and check to make sure the flash is set to off.
1/17/2012 6:39:08 PM • Fuji Rod Repair... • Answered on Jan 17, 2012
0answers
Why is my camera displaying
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/21/2011 10:23:06 PM • Fuji Rod Repair... • Answered on Sep 21, 2011
The lcd screen on my ax245w is black. Was working
Mine has just done the same, what did you do to fix it?
7/20/2011 7:55:51 PM • Fuji Rod Repair... • Answered on Jul 20, 2011
I have a FinePix Z5
Welcome to Fixya. I would like to know the error that you have encounter? FinePix is Z5 is compatible with Windows 7. I have provided the Download link for the driver and software below. Please do check it and if necessary please install the updates.
FinePix Z5 Download
On the top of the page you will see the tabs of the category of the software and downloads.
Thanks for using Fixya.
7/16/2011 7:10:23 PM • Fuji Rod Repair... • Answered on Jul 16, 2011
I have a Finepix S
Please check if you can access the card on a computer?
If you could format the card from a computer and choose the file system to be fat32.
Also make sure that the contacts are clean and make sure that the slot you have to put it in the camera is cleaned too. If the problem persist the problem could possibly be the contact on the camera not properly touching the contacts on the card that's why it's not able to remove the permission from it.
It would be better to have a camera technician look at it for you as it would involve opening the camera and cleaning or possibly replacing those contact pins.
Hope this helps!
7/11/2011 10:50:05 PM • Fuji Rod Repair... • Answered on Jul 11, 2011
WHEN I TRY TO TAKE
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
6/22/2011 5:23:10 PM • Fuji Rod Repair... • Answered on Jun 22, 2011
Help! I need a manual
Here's a link to the manual for this item. The manual is in PDF format so make sure you have Adobe reader or another similar pice of software installed:
http://fujifilm.co.uk/media/dContent/171191/productFilesManualsFile.pdf
5/5/2011 11:30:59 AM • Fuji Rod Repair... • Answered on May 05, 2011
Fuji Rod Repair Kit Logo
130 questions posted
Top Fuji Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Fuji Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Fuji Sport & Outdoor - Others
Most Popular Question
lcd screen ax245w black working
  • Sport & Outdoor - Others
