20 Most Recent
kawasaki Full Suspension Mountain Bike Men Questions & Answers
Need a kawasaki zxi 1100 owners manual
Most of the time you can look up the owners manual on websites as long as you can find the kawasaki website you should be good, i had the same problem with a dirt bitke and i found there website and found the owners manual and downloaded the owners manual and printed it out. Hope i was of some help to you.
POPPING THROUGH EXAUST
If it didn't pop after the valve adjustment, try adjusting the valves again.
Popping out the exhaust usually indicates a burned exhaust valve. The valve doesn't seat all the way around and air/fuel mixture is getting into the exhaust header on the compression stroke and igniting from header heat. The reason this doesn't happen at higher rpms is the amount of time for the air/fuel to leak it really short.
Kawasaki kx80 has no spark
hi mate replace wires/cables and put another spark plug in it could be spark plug fouling and try the cdi in another kx80 also replace hd lead from coil to sparky
KX80, overheating ?
I'm not familiar with this bike but it sounds like it could be air locked and causing it to overheat.I found the best way to remedy problems like this is to get it up to temp,shut off and lay bike down too one side then the other.Tilt forward then back,check to see if coolant level dropped.If that dont work pull a vaccum on cooling system and see if it holds when warm.
