20 Most Recent Peg Perego Vespa Scooter Questions & Answers
Could be worn or sticking float valve, located in bowl of carburetor. to test turn off fuel, remove bowl from carburetor, gently raise floats all the way with finger, turn on fuel, it should not leak until released.
Peg Perego Vespa... | Answered on Dec 16, 2018
these toys don't have engines, just electric motors
Peg Perego Vespa... | Answered on Dec 08, 2018
check your takn and clean your fuel and air filter and check the fuel line from the tank to the carb and blow it out, 1 of these should help.
Peg Perego Vespa... | Answered on Nov 17, 2018
frankly speaking:
how come you think it is "not a problem" to do such service jobs on a Vespa LX if you are not a mechanic and don't have all the tools required?
- sure you could try it - but you need enough time to check the workshop manual and get the proper tools. (eg. sometimes the nut on the rear axle is stuck and need to be heated by a torch)
- to change the tubeless tire you will need also a tire changing machine which only tire shops or bikedealers have. https://www.yumpu.com/en/document/view/26764401/service-station-manual-vespa-lx-125-150-4t-euro-3
Peg Perego Vespa... | Answered on Nov 16, 2018
2% as most Vespas. Some folk like to add a bit more for a tuned engine.
- did you ever push the starter button while the engine was running?
if yes, the gear on the starter motor is damaged and needs to be replaced...
It is on the side of the carb. Look for a large hand knob.
Peg Perego Vespa... | Answered on Apr 23, 2018
All Vespa's old or new run without need of lead as your engine internals are lubricated by either the gear oil or 2 stroke oil.
Peg Perego Vespa... | Answered on Mar 06, 2018
incorrect float level setting
needle and seat not properly installed
try having the carby professionally overhauled
Peg Perego Vespa... | Answered on Dec 16, 2017
You may have an underlying problem that your overhaul has missed but maybe a fast flow fuel tap could be the answer ? You don't state exactly which model you have but have a look here http://beedspeed.com/product_info.php?products_id=8958
Peg Perego Vespa... | Answered on Sep 11, 2017
most likely need new batteries, if there was a bang, i'd check to make sure one of the batteries didn't explode
Peg Perego Vespa... | Answered on Aug 18, 2017
Hey June, the correct assembly. cleaning. setting, and adjustments of the carburetor are CRITICAL....Please take the carb to a qualified professional to get it cleaned and set. Ask him which screw sets the idle speed..and you can set it when you reassemble it.. (ONLY adjust the idle speed screw!!)
IF this machine has oil injection, and its been working fine.. do not adjust it...AND .. if the oil is injected into the carb (i've seen one or two bikes with this set-up)..its working fine..the fuel/air will be taken care of when the carb is fixed! Make sure your air filter is clean!!.. and a new spark plug will help!!
Peg Perego Vespa... | Answered on Jun 28, 2017
check:
- is gasoline in the tank?
- is there a spark emitted at the spark plug if held to the cylinder while cranking the engine.
- is the headlight lighting up while cranking?
use a starter-spray in the air intake
Vespa 150GS VS5 spark check
Peg Perego Vespa... | Answered on Dec 21, 2016
Blue smoking no power
Peg Perego Vespa... | Answered on Oct 06, 2016
i think it is the CDI-box (at the top end of engine) not working.
check the connectors (pull the rubber cover)
- or better get a new onevespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-0.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-2.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-5.jpg
Peg Perego Vespa... | Answered on Nov 29, 2014
Peg Perego Vespa Scooter Logo
Popular Tags
248 questions posted
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
vbb vespa scooter 1961 wont start
  • Toys
