20 Most Recent Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Questions & Answers
have you tried to adjust the valves?
Craftsman 26 hp... | Answered on Feb 05, 2018
There is not an adjustment on the parking brake. The problem you are having may be caused by the drive belt stretching.
Craftsman 26 hp... | Answered on Jan 02, 2018
You could have made this comment in the post I answered. Please don't answer questions as a new post.
So please give us a full run down of what the problem is. Is all you have said is 'Is it the pulley', and it doesn't come or or slip'. That is not enough information to tell us what problem you have.
Reply as a COMMENT to this post please.
Craftsman 26 hp... | Answered on Apr 01, 2016
look at the tie rod ends . they are adjustable .
Craftsman 26 hp... | Answered on Oct 22, 2015
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Craftsman 26 hp... | Answered on Oct 19, 2015
If your engine stops and then the carburetor floods, your needle and seat is not closing correctly. This can be caused by dirt or varnish being caught in the needle and seat.
A good clean with some carburetor cleaner will remove any dirt or varnish buildup from the carburetor. Then while you have it apart give the float a shake to see if it has a leak.
If there is any liquid in the float you will need to replace it.
Craftsman 26 hp... | Answered on Jun 08, 2015
If you are talking about the spark plug, I would need the model number of the engine.
Craftsman 26 hp... | Answered on Sep 18, 2014
bad check valve in hydrostat does motopr have normal power i asume it does
Craftsman 26 hp... | Answered on Sep 11, 2014
searspartsdirect.com
Craftsman 26 hp... | Answered on Jul 11, 2014
I am sorry, I can't help you, they could not answer my question.
Craftsman 26 hp... | Answered on Jun 16, 2014
are you putting it on backwards or opposite the way it came off maybe
Craftsman 26 hp... | Answered on Nov 06, 2013
There is no way to check the level without removing the trans. These transmissions are sealed for life.
Was there a leak? If there were no leaks, don't worry about the level. If there was a leak you should have a qualified tech check the fluid level.
Craftsman 26 hp... | Answered on Nov 03, 2013
You have to remove the nut on top of the pulley. With the pulley off, the shaft will slide out the bottom with the blade. Don't forget when you put the pulley back on, the washer/spacer goes BETWEEN the pully and housing, NOT on top of the pulley. Dwain
Craftsman 26 hp... | Answered on Nov 01, 2013
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
155 questions posted
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
belt doesnt come off or slip
  • Garden
