20 Most Recent
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Questions & Answers
Bled on cutting deck spins free and will not cut
I assume you mean the blade on cutting deck?
Is the pulley that drives it still firmly connected to it? (I mean the pulley and the blade spin together as one, and not independently)
If the blade is loose on its spindle check under the deck for damage, and that the blade securing bolt(s) are intact and tight.
If the problem is that the pulley isn't getting driven by the deck belt, that is a different story. Most likely the deck belt isn't getting enough tension to grip the pulley. Check the tensioner is working properly and the spring is still hooked up and working.
Craftmans mover blade keeps hitting ground
Is the deck too low or one side lower than the other? Level the deck side to side, front should be a little lower than back (about 1/4 inch). check tires for correct air pressure. Make sure blades are balanced.
