20 Most Recent
Bamix Deluxe Handheld Blender Questions & Answers
25-30 year old Bamix M100 - 240V 100W
Those small plastig bungs do come out, you will need a fine probe to prise them out then you will see 2 philips head screws which hold it all together, not sure how you will tighten your shaft though, looks like it might be moulded into the plastic retainer, good luck! on mine the motor bearings are seized,
regards,
Dave Pary.
My mayonnaise won't work it is just runny
I believe the issue is more with the method of preparation. Try slowly adding the oil when preparation the mayo and that should alleviate the problem.
Good luck and Happy Eating,
Alex
How to use bamix to make bread dough
I have several recipes for bread both yeast and none. But not enough space here.
French Bread.
Use C blade. 3c plain flour.2Tbs rapid rise yeast. 3 Tbs sugar. 2Tbs salt
1c water. 2/3 c of milk. 3Tbs margarine or oil. heat together until 130F/55C add to yeast mixture and stir in with C blade add in an egg and stir.Empty onto a floured counter. Knead by hand for 8-10 mins cover and let rest for 10 mins.
Divide dough into 2, shape into loaves place on greased cookie sheet cover and let rise 15-30mins. Bak in a 400F/200C oven 18-20 mins until light brown,Remove cool and enjoy.
Making meringue with hand held bamix
Use the A blade and make sure whatever you are mixing the egg whites in is scrupulously free from any grease etc. Make sure the bowl is clean and dry before you use it.
Best wishes
Blade slips off
Keep tightening it with needle nose pliers and make sure the notch is in the right place.
Instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise
1 egg (or 1 egg yolk)
1 teaspoon of lemon juice
1 teaspoon of herb vinegar
1 pinch salt
1 pinch pepper
1 ½ - 2 cups of oil
1 teaspoon of french mustard
Put all the ingredients except the oil in a jug (not too large)
and blend well with the WHISK. Then add the oil in a thin, steady
stream (not drop by drop), processing all the time, until the
mayonnaise has reached the required consistency. To achieve perfect
results, all ingredients should be at the same temperature.
go back
I have a bamix M200 hand blender & the shaft d...
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
The plug has sheared off,can
Remove the 2 screws on the top cover with a security torax screwdriver.The cord and switch assembly will lift out quite easily. Solder on the new cord.Put the cover back on.
