20 Most Recent Lincoln X2688 2 YR EXTENDED WARRANTY FOR SP140T Questions & Answers
Have a lincon 255Xt mig welder. You push the
Have you checked the tension on the wire roll feeder? Inside the unit where the spool is, the wire feeds off of the spool, through the feed roller, this roller has a tensioner spring on it that keeps the wire flowing steady, and also check the spring tension the keeps the spool from turning freely, keep this loose as can be, and just enoughthat it doesn't unwind on it's own.
There are so many things that it can be, but this is a start.
Good Luck.
Paul
5/10/2010 2:38:02 AM • Lincoln X2688 2... • Answered on May 10, 2010
2answers
Auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
12/8/2009 10:30:34 PM • Lincoln X2688 2... • Answered on Dec 08, 2009
Machine will not idle down and shuts off when the
When the unit is cold remove the spark plug and check the intensity of the spark and do the same when the welder shuts off when it gets hot. could be a bad coil or another component in the ignition system.
8/28/2009 2:02:38 PM • Lincoln X2688 2... • Answered on Aug 28, 2009
My pro cut 55 Lincoln plasma cutter sounds like a machine gun when I strike it and put it to the metal. It cuts holes when you hold the trigger down and try and make a continous cut. new air dryer
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjs8bCkuK6DAxWckIkEHe3TDjsQFnoECBMQAQ&url=https%3A%2F%2Fweldingweb.com%2Fvbb%2Fthreads%2F710111-Lincoln-Pro-Cut-55-Problem&usg=AOvVaw0cDjkvgYBijIMdD5HSUUUq&opi=89978449
12/27/2023 1:15:05 AM • Lincoln Welding... • Answered on Dec 27, 2023
I have a Lincoln Ranger 250 gas welder it runs but it won't strike a arc where should I start looking for the problem?
If your Lincoln Ranger 250 gas welder is running but not striking an arc, there could be a few potential issues causing this problem. Here are some steps you can take to troubleshoot the issue: 1. Check the welding leads and connections: Ensure that the welding leads are securely connected to both the welder and the workpiece. Make sure the connections are tight and free from corrosion or damage. 2. Check the electrode/ground clamp connections: Inspect the electrode holder and ground clamp connections for any loose or damaged parts. Ensure that the electrode holder is securely gripping the welding electrode. 3. Check the welding electrode: Examine the welding electrode for any signs of damage or wear. Replace the electrode if it appears worn out, as it may not strike an arc effectively. 4. Check the power source: Verify that the power source to the welder is adequate. Ensure that the welder is receiving the correct voltage and that the power source is providing sufficient power. 5. Check the welding settings: Review the welding settings on the welder to ensure they are appropriate for the type and thickness of the metal you are working on. Adjust the settings if necessary. 6. Check the welding environment: Make sure you are operating in a clean and well-ventilated area. Remove any contaminants or debris from the workpiece and ensure good contact between the workpiece and the ground clamp. 7. Check the welder's internal components: If the above steps do not resolve the issue, it may be necessary to inspect the internal components of the welder. This requires expertise and should be performed by a qualified technician. Contact a professional repair service or the manufacturer for assistance. Remember, safety is crucial when working with welding equipment. Always follow proper safety precautions and wear appropriate protective gear, such as welding gloves and a welding helmet, to protect yourself from potential hazards. These might help
6/21/2023 4:11:28 AM • Lincoln Welding... • Answered on Jun 21, 2023
Lincoln 100 with gas. Was working fine then suddenly when I pull the trigger it appears to experience an internal short circuit.
It sounds like there may be a problem with the internal circuitry of your Lincoln 100 welder. Given that the welder is tripping the breaker and dimming the lights in the garage, there may be a significant amount of current passing through a fault in the machine's electrical system.
I would recommend that you do not attempt to operate the welder until the issue has been resolved. Welding equipment can be dangerous if not properly maintained and operated, and it's important to take safety precautions to avoid injury or damage to your property.
Since you've already inspected the inside of the welder and didn't find anything obvious, it may be best to take it to a qualified repair technician. They will have the expertise and equipment to diagnose and fix any problems with the machine's electrical system.
Alternatively, you can contact the manufacturer's customer service for guidance or recommendations on qualified repair technicians in your area. They may also be able to provide additional troubleshooting steps to help diagnose the issue.
In any case, safety should always be your top priority when working with electrical equipment.
3/21/2023 1:40:59 PM • Lincoln Welding... • Answered on Mar 21, 2023
2answers
My 2012 Lincoln classic 300d welder, while I'm welding it will just idle down
If it's a Perkins engine, odds are that you need a rebuild kit for the governor or a new governor to maintain the idle. It's a fairly common issue and repair.
12/18/2022 4:54:01 PM • Lincoln Welding... • Answered on Dec 18, 2022
My Lincoln le31mp was welding fine putting good hot flat beads down and 10 min later with the heat all the way up it's acting like it can't get the wire hot enough it's just sitting up on the metal
Check the duty cycle specs. The specs should tell you how many minutes you can weld at certain amps before the machine has to cool down for x amount of time before it will at the specified amps again. From your post that sounds like what you're up against. Hope this helps.
10/25/2022 7:00:52 AM • Lincoln Welding... • Answered on Oct 25, 2022
Lincoln Weld-pak 140HD constantly feeds wire without squeezing trigger
Hi, Please check your relays and contactors. If a relay is shorted on, this issue would occur. Also, please check that your contactors are not stuck. Thank you.
10/18/2022 8:59:32 PM • Lincoln Welding... • Answered on Oct 18, 2022
MY LINCOLN 8 WELDER
governor spring worn or loose screws on the goveror itself
10/16/2022 2:09:30 AM • Lincoln Welding... • Answered on Oct 16, 2022
Would like to know how to access my spark plugs on my Lincoln Ranger 330mpx. Have done all maintenance so far but spark plugs are barely coming due
https://www.manualslib.com/manual/1750612/Lincoln-Electric-Ranger-330mpx.html?page=45#manual
10/5/2022 3:08:23 AM • Lincoln Welding... • Answered on Oct 05, 2022
2answers
Is it possible to fix bad piston rings on a lincoln welder ranger 250gxt or is it better to just call it over on the welder?
rings can be replaced, cylinder can be re bored and use oversize rings and piston.
7/26/2022 11:54:28 PM • Lincoln Welding... • Answered on Jul 26, 2022
Lincoln sp 175t. drive motor
relay blown in side it will be in the main unit not the wire feed if it is digatal circut bord
4/30/2022 1:23:18 AM • Lincoln Welding... • Answered on Apr 30, 2022
Lincoln 100 HD mig welder arcing at the beginning of the liner just past the feeder wheels, I changed the liner, it didn't make a difference?
The feeder motor, gearbox and all the rest of the feeder unit is mounted on a fiber plate to insulate it from the case of the machine. Something is grounding these parts to the machine frame. It might be some tools laying in the bottom or a buildup of scale and conducting dirt inside the machine. If you understand what I am telling you, an ohm meter set to ohms X1 may help you find the problem. Let me know if you locate the problem.
9/14/2021 9:40:28 PM • Lincoln Welding... • Answered on Sep 14, 2021
250 ranger gas welder. Why wouldn't it shut off?
Check and clear gas valve for possible failure
5/7/2021 11:57:41 PM • Lincoln Welding... • Answered on May 07, 2021
Wiring diagram for Lincoln 140 had wire welder bridging plug on gun to machine
Request the wiring diagram from Lincoln.
3/24/2021 1:41:58 AM • Lincoln Welding... • Answered on Mar 24, 2021
I have a lincoln a/c d/c welder has a light humming noise when plugged in on d/c + but won't weld
best to call Lincoln or the welding shop you bought it from.
1/18/2021 2:19:37 PM • Lincoln Welding... • Answered on Jan 18, 2021
Lincoln X2688 2 YR EXTENDED WARRANTY FOR SP140T Logo
4 questions posted
Top Lincoln Welding Tools Experts
Sean Wright
Sean Wright
vince
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Lincoln Welding Tools
Most Popular Question
lincon 255xt mig welder push
  • Welding Tools
