20 Most Recent
Black & Decker Jump Start System 450 Amp Instant Starting Power/ Compressor Questions & Answers
I have the Endurance 300
If it's like mine, it probably won't charge. First time I let it run down, it was screwed, a real POS.
Will not charge, no indicating lighting
This is a possible problem. Check and see if the compressor has a fuse in it. If you have the manual it will tell you if it has a reset fuse if not check and see if the outlet there’s a fuse. I’ve had the same problem with the one I have. Hopefully it works if it doesn’t I’m sorry
2001 pontiac grand am se trouble starting
I am guessing this is for cold startup. Sounds like it in the cold start cycle, which would include a sensor and some method for fuel enrichment and idle speed bypass. If it has this problem on a warm start it sounds like a defective temp. sensor. It may show up on a control computer readout. Hopefully, it is only a sensor!
