20 Most Recent
Milwaukee Tool Case Heat Gun Questions & Answers
Case 60xt alt puts out **** will not charge
Alot of things to check.....basics first.
1/ Fan belt loose.
2/ Battery low on water, top cells only just above plates. NOT FULL.
3/ Loose / corroded battery terminals.
4/ Wiring to alternator loose / broken / no power to field circuit (Does it have a charge light?) If so is it on with key on and off when engine is running? If no to either then wiring to alternator faulty or internal alternator fault.
5/ Is battery in good condition? If not sure fit a known good battery and try.
6/ Using multi meter, place across battery terminals, should read 13.5-14.5Volts with engine running. These test are only accurate on a known good battery as any internal resistance of the dud battery will show low er than normal voltage readings.
Deisel fuel getting to injector pump. Feul also
you prabably have an airlock inside the injector lines.
Disconnect two lines and crank again,this will push out the air so fuel can get to the injectors.once the fuel comes out reconnect the lines and it should start
Case 410 Uni Skid Steer Loader Service Repair
I have a 2005 Case 410 that has 391 hours on it just had the oil and air filters changed 10 hours ago. While using the skid steer it suddenly shut down on me and wont start when I turn the key the hour meter reads ACC. I checked the voltage on the battery checked out at 13 volts coming out, and tried jump, no go. Checked the oil which was at a right level and seemed fine. Cane anybody help me thanks, email me at
[email protected] Thanks
