20 Most Recent
Coleman Powermate Portable Generator PM0435003 Questions & Answers
Coleman Powermate 10 hp Briggs
Yes, If there is room I would use a spst toggle switch. This is a very common switch. Try ebay, HD etc. If there isn't a similar switch can be found at ebay. Good Luck
10/14/2017 8:04:58 PM •
Coleman...
Answered
on Oct 14, 2017
At 3600 rpms generator produces 133 volts AC
You cannot, speed is propertional to voltage on these, as they have capacitor voltage regulation. Do not use this for powering home appliances, it is common to see this design and not a problem. If you add load and it will decrease but so will the frequency
7/10/2015 4:25:46 PM •
Coleman...
Answered
on Jul 10, 2015
How do i separate the engine from generator on powermate 5000
It generally has a long rotor through bolt accessibile from the generator end, this forces the generator rotor onto a tapered shaft on the engine. Once removed the through bolt slide a long bar ion the hole and screw the bolt back in, that will force it off the taper
11/29/2013 5:56:02 AM •
Coleman...
Answered
on Nov 29, 2013
Pmo 0544655
Take the through bolt out of the end of the alternator / rotor shaft. it is a long bolt. The shaft from the engine is tapered and unlikely to just pop off. Find a bolt that will screw into the end of the rotor shaft (hardend) find a metal bar that will slide into the rotor long enough so the bolt tightens down on the bar, it will pop the alternator off the tapered shaft
11/18/2013 12:00:30 AM •
Coleman...
Answered
on Nov 18, 2013
