20 Most Recent Rohl R77V3SPN Country Pull-Out Bar Faucet with Short Handspray - Polished N... Questions & Answers
2answers
Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
12/18/2014 12:48:10 AM • Rohl R77V3SPN... • Answered on Dec 18, 2014
2answers
Would it be cartridge or something else
Not the cartridge. There are O Rings around the spout that wear out. These need replacing. Call Rohl for replacement parts www.rohlhome.com/warranty.aspx
7/28/2014 2:20:57 PM • Rohl R77V3SPN... • Answered on Jul 28, 2014
How do I replace the hose on a rohl 3810 faucet
contact ROHL customer Service, request a new hose (part number R45158), detach the end on the underside with a wrench and pull it out. Insert new hose through the topside guide neck and reconnect on the bottom connection.
12/6/2013 11:04:35 PM • Rohl R77V3SPN... • Answered on Dec 06, 2013
Guide to Replacing Cartridge on Rohl R77V3
Look carefully at all the prongs and receiving slots in the body of the faucet into which the cartridge goes to insure proper match.
9/30/2013 10:10:44 PM • Rohl R77V3SPN... • Answered on Sep 30, 2013
2answers
Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
3/22/2011 11:21:53 PM • Rohl R77V3SPN... • Answered on Mar 22, 2011
I have a Rohl R77V3STN Pull Out Faucet, and the
Call customer service right away. 1 800 777 9762
Mine is now stuck, and she said if I had called when it was still moving, they could send a free part. The only other option would be that they send a refurb faucet for a $50 charge. I said no thanks, I'm not paying another cent for this faucet--there's a lifetime warranty! The warranty states replacement of product or parts free of charge.
I'll try the part. as the faucet will move if I force it. (I used a little wd40).
Apparently mine was made in New Zealand, where the water doesn't have as much chlorine.
If the part doesn't work, I'm calling them back and raising the roof!!
10/4/2010 7:15:41 PM • Rohl R77V3SPN... • Answered on Oct 04, 2010
I'm going tobe replacing the cartridge in my Rohl
It is highly suggested to use the grease. The purpose of the grease is for (break-in Period). Without the grease, gaskets and seals rub dry and hard against the metal surfaces and could distort or wear uneven and fail prematurely. The grease helps ease the initial wear and give a better life. Also, it isrecommended toopen a faucet and clean and grease seals and gaskets before they are bad;sort of a preventive maintainance every 2 to 3 years. Good luck, Macgivor
1/16/2010 2:42:17 PM • Rohl R77V3SPN... • Answered on Jan 16, 2010
I have a R77V3 in
  • Everything you will need to know can be found. Pics and Step By Step Directions.
  • If you have any questions, just ask me
  • http://plumbing.hardwarestore.com/learning/how-to-repair-faucets.aspx
Just copy and paste the above link in our internet address bar under a new tab.
10/11/2009 3:55:28 PM • Rohl R77V3SPN... • Answered on Oct 11, 2009
I have a Rohl kitchen faucet There are greenish white particles collecting in the screen at the head of the faucet. It clogs and water is greatly comprimized
"lime scale deposits." That's lime scale, or scale deposit, forms because your tap water is "hard" with dissolved minerals. Pure lime scale is white, But your lime scale can turn green from copper pipes or fixtures. You don't need to replace your faucet. You could install a under cabinet filter. Or a whole house filter that would help allot.
4/6/2023 3:03:21 PM • Rohl Plumbing • Answered on Apr 06, 2023
My spray head on my Rohl single lever country kitchen faucet is stuck. How do I fix it?
Try soaking it overnight in white vinager.
10/7/2018 8:23:48 PM • Rohl Plumbing • Answered on Oct 07, 2018
I am trying to replace the pull out hose on my Rohl kitchen faucet. what should be a simple task has all ready taken over an hour, the hose will not pull through the faucet.
The tolerances are very close in this faucet. Take a long slender screwdriver, and from under the sink stick it into the end of the hose to guide it through the very small passageway. It is much easier if you have someone gently pulling from above while you try to line it up. Good luck!
10/3/2018 4:54:24 PM • Rohl Plumbing • Answered on Oct 03, 2018
In trying to replace the cartridges in my sink, I can't figure out how to remove the handles from the old sink. There are no set screws & wonder if it is just threaded on the lower part of the sink.
some have grub screw holding the on handles, some have a screw on the top under a plate . If you know the make you can look on u tube to see how they come off.
7/13/2018 2:11:35 PM • Rohl Plumbing • Answered on Jul 13, 2018
Spray nozzle leaks
That would be your best bet very well could be a bad sprayer housing
1/23/2018 5:32:40 PM • Rohl Plumbing • Answered on Jan 23, 2018
I have a Rohl
Appears you have a blockage in the hose itself. Remove and use a piece of wire to clear the blockage.
1/14/2018 1:03:42 AM • Rohl Plumbing • Answered on Jan 14, 2018
My Rohl faucet stopped working but the side sprayer stays on when i turn the water faucet handle on
Sprayer stuck in on position and by passing the faucet
1/5/2018 10:33:14 PM • Rohl Plumbing • Answered on Jan 05, 2018
Rohl perrin and rowe country bathroom faucet cannot be removed to change to different sink
All faucets can be removed.
11/12/2017 2:17:49 AM • Rohl Plumbing • Answered on Nov 12, 2017
Rohl R77V3SPN Country Pull-Out Bar Faucet with Short Handspray - Polished N... Logo
33 questions posted
Top Rohl Plumbing Experts
vince
Paul Carew
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Rohl Plumbing
  • Rohl Plumbing
Most Popular Question
going tobe replacing cartridge in rohl
  • Plumbing
