20 Most Recent American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Questions & Answers
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
American... | Answered on Oct 27, 2018
same here..some duct tape should do the trick or you can pay for a repairman
American... | Answered on Aug 22, 2016
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
American... | Answered on May 20, 2015
shut off valve got turned perhaps
American... | Answered on Jan 24, 2015
IF IT WILL NOT COME OUT THEN THERE HAS GOT TO BE A SMALL SCREW OR SOMETHING HOLDING IT ON. IF AUCET IS TO TIGHT IT WILL NEED TO BE LOOSENED JUST A BIT. THERE MAY ALSO BE RUST OR DIRT IN IT AND YOU WILL NEED TO TAKE IT OFF & CLEAN IT WITH VINEGAR OR RUBBING ALCOHOL THEN PUT IT BACK ON.
American... | Answered on Jan 21, 2015
What exactly do you mean by 'not come out'? Is it coming out at all and has it ever? How long has this been happening?
If it is coming out slowly or barely, but has worked properly at one point, then the problem is most likely the cartridge. It gets full of lime deposits and sediment. What I would suggest is, if you are handy around plumbing, disconnect the sprayer handle and the cold water hoses and blow them out, use canned air if you are able. Then try pouring vinegar in and run through a few times, catching the drainage in a cup or something. The vinegar breaks down the deposits and is always a good maintenance idea.If that doesn't do the trick,my second step would be to call American Standard. Their customer service is awesome! They will most likely send you a replacement or replace your entire faucet. If you just want to get it working and don;t want to take the time to do the other, you can get the replacement cartridge at most larger home improvement centers. G'luck
http://www.plumbingwarehouse.com/images/american-standard-kitchen-faucet-easytouch-6310.gif
American... | Answered on Aug 07, 2014
You have a water valve or back-flow preventer slamming closed, somewhere...
American... | Answered on Mar 09, 2014
Take the red/blue plastic plug out and use a hex key to unscrew the handle.
American... | Answered on Feb 23, 2014
Replace the cartridge
American... | Answered on Jan 29, 2014
Without seeing the faucet or knowing any other details, it sounds as if the o-rings or seats are bad. Most likely twisted or misaligned if the problem is such that it won't turn off. If the faucet assembly is loose, these small components can come out or become misaligned. Write down all the information you can about the specific brand and model faucet, then take this down to your local hardware professional and ask for the rebuild kit. You may need valves in addition to seats, springs, washers and o-rings (depending on the model). Most companies have kits for doing these rebuilds. Check also the seal made at the seat. If this is not tight, water will flow. Be sure you ask which, if any, special tools are necessary to remove the faucet assembly and various components. These tools are sometimes standard and sometimes specialized or unique to a certain brands/models (ie: handle pullers, seat pullers, valve wrenches). Final tip: before doing any faucet work, always remove the aerator to allow any debris to pass through the line and flush thoroughly upon completion before reinstalling the aerator.
American... | Answered on Dec 13, 2013
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
Popular Tags
91 questions posted
Top American Standard Plumbing Experts
Thomas F. Schneider
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Plumbing
Most Popular Question
american standard kitchen faucet low
  • Plumbing
