20 Most Recent
Hitachi RD5086P 8.3-Cup Rice Cooker Questions & Answers
HITACHI RD 5083 RICE MEASUREING CUP
Good Morning to you
you have undoubtely found a way to measure the water and the rice, since you posted your question.
i have found that 2:1 ratio makes best rice.
2cups water and one cup rice to start with. Ajust as needed the time as well. Start with 20 minutes.
kolbrun
Where can I order the inner metal pot.
Good morning
if there is not a dealer in your neighbourhood you can always try some of the one on this screen shot. Kolbrun
I know this is not a good screenshot so maybe it would be better for you to Google yourself. Look for " Inner pot rice cooker replacement" on
https://www.google.co.uk/
Hitachi Rice Cooker/Steamer RD-5083. Need new
hi, I'm looking for the user's manual and found your question.
You can fix it using a piece of wood and screwing it with a Stainless Steel sheetmetal screw (like a #6x1/2"lg ss)
You can also painted if you like it.
What is the ratio for
It all depends on the type of cooking desired, if it needs to be dry or as a soup( gruel) againit depends on the type or variety of rice. So your experience will prove you right.
I think a ratio of one cup to three cups should be good. You can check and add if there is absorption before being cooked finally.
How much water to each cup rice?
Two cups of water for each cup of rice should get you nice results. If you choose to rinse your rice prior to cooking, it's recommended that you compensate by putting slightly less water in the rice cooker, to compensate for any absorption.
Hope this helps :-)
Amount of Rice
The Japanese measuring cup size of 200 ml works fine for my Hitachi RD-5083 and likely will work for most rice cookers. The standard US cup is 237 ml.
