20 Most Recent Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout .... Questions & Answers
2answers
How do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
2/25/2022 6:19:13 AM • Moen Monticello... • Answered on Feb 25, 2022
The cartridge collar of our Moen Monticello faucet
It sounds like the fine threads on the collar are stripped. Either replace the collar, or try some locktite.
3/3/2018 7:32:00 AM • Moen Monticello... • Answered on Mar 03, 2018
I have a Moen 7730
Parts for that model can be found at amazon, take a look: Were doing more than just throwing away the key. Have a nice day
11/1/2016 10:41:34 PM • Moen Monticello... • Answered on Nov 01, 2016
Moen monticello kitchen spout does not rotate
It needs to be taken off and lubed. If you don't have plumber lube you can use vegy oil but it will not last like plumbers lube.
10/11/2016 8:28:58 PM • Moen Monticello... • Answered on Oct 11, 2016
What do i need to do to get a better water flow from my moen kitchen faucet #7700. when you turn on and wash hands it sprays water all over counter-
Sounds like your spray head on the faucet needs replacing. They do plug up with rust and corrosion every so often. You can take it off and try to clean it but be very careful it may still spray when you put it back together.
2/9/2015 7:34:11 PM • Moen Monticello... • Answered on Feb 09, 2015
Repair moen single lever faucet
All Moens are the same- so no matter what model u have- u do the same thing. U have to pull the valve out. It's very hard to pull. It may take several tries- don't be afraid to pull. My husband is a plumber. He said they're difficult to get out. U just have to pull. Hope this helps! Good luck!
9/5/2014 9:56:48 PM • Moen Monticello... • Answered on Sep 05, 2014
Moen 7700 cartridge replacement
This is the exploded view. The cartridge is available at any hardware store. http://www.moen.com/shared/docs/instruction-sheets/ins111a.pdf
7/24/2014 4:41:17 AM • Moen Monticello... • Answered on Jul 24, 2014
There is a leak where the spray arm connects to the water faucet under the sink. The connection is a snap connection rather than a screw on type.
With this type of faucet when you push the 2 pieces together there should be a small rubber O ring, if this is not in the correct position there won't be a proper seal. If you have some vasalien rub it on the O ring and it should help it fit better, it also should click when you push it together.
4/13/2014 12:41:49 PM • Moen Monticello... • Answered on Apr 13, 2014
I have a single-handle Moen
Yes you should have a lifetime warrenty. Call 1-800-buy moen for replacement parts. They generally are very good about taking care of their productc however be prepared for a extended wait to get through. You can buy after market or genuine moen part at most lowes or ace hardware stores. Hope this helps. Thank you
7/17/2013 9:17:56 PM • Moen Monticello... • Answered on Jul 17, 2013
3answers
Moen balancing spool
Moens balancing spool moves back and forth inside the cylinder to regulate flow of water to keep you from getting scalded. If it is not working properly you can get to much of hot or cold water coming out of the spout....or low to no water coming out.
1/14/2013 4:59:16 AM • Moen Monticello... • Answered on Jan 14, 2013
2answers
Moen 7700 leaking at base of faucet. how do you
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.htmlThere is also a video at the bottom of the blog post showing how I did it.
1/3/2013 1:06:58 AM • Moen Monticello... • Answered on Jan 03, 2013
2answers
Need to replace O Ring but cant pull the spout off
there might be a allan screw holding it down usually located at the back of the faucet if not there is a chance that there is a screw on escutcheon just above the base of the spout this should screw off with a strap wrench.
12/24/2012 9:25:53 PM • Moen Monticello... • Answered on Dec 24, 2012
7700 series Moen leaks at
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.htmlThe replacement o-ring and retainer parts were free to me. Hope it helps you.
12/24/2012 9:19:36 PM • Moen Monticello... • Answered on Dec 24, 2012
Moen 7400 fix
http://www.moen.com/shared/docs/instruction-sheets/ins111a.pdfIf you mean part #16 in the blow up diagram, assembly number 15 must be fully seated for the clip to enter and seat.into part 17.
1/16/2012 5:45:13 AM • Moen Monticello... • Answered on Jan 16, 2012
2answers
Ever since my Moen kitchen
There may be construction debris or residue partly blocking the aerator. Have you unscrewed the end and cleaned it out? Sometimes the fellow may not have assembled the aerator in the right order and a simple rearranging of parts will clear it up.
Regards, farmerbear
9/28/2011 9:48:43 PM • Moen Monticello... • Answered on Sep 28, 2011
How to remove the cathedral
Grab the base of the spout and turn it counter-clockwise.It should come right off.
6/3/2011 8:34:00 PM • Moen Monticello... • Answered on Jun 03, 2011
Moen cathedral keeps coming loose
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
5/4/2011 3:32:25 PM • Moen Monticello... • Answered on May 04, 2011
No Hot water coming out
Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
Soak the dirty cartridge in vinegar for four hours and replace.
If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
2/8/2011 7:54:02 PM • Moen Monticello... • Answered on Feb 08, 2011
Water is dripping from the spout, and leaking from
http://www.moen.com/shared/pdf/7730pt.pdf
http://www.moen.com/shared/pdf/instruction_sheets/ins108f.pdf
These two links should help you with this task.
The screw to take the handle off is behind the little puge on the frount of the faucet handle.
2/6/2011 9:39:57 PM • Moen Monticello... • Answered on Feb 06, 2011
How do I clean the
If you are talking about the areator you can remove it by turning it to your right . You can remove the screens and brass disc and clean them with soft brush and cleaner like mild C.L.R. and water solution. This will clean lime and mineral scale from them. Do not use this on outside finish. Use softscrub and soft cloth to clean. If the finish is too badly discolored you can get replacements at most hardware stores or for special finishes go to moen.com for location of dealer nearest to you. To install just reverse steps. I hope this helps you. Thanks
11/26/2010 5:54:14 PM • Moen Monticello... • Answered on Nov 26, 2010
Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout .... Logo
Popular Tags
88 questions posted
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Moen Plumbing
  • Moen Plumbing
Most Popular Question
moen 7730
  • Plumbing
