20 Most Recent Samsung CLX-3175FN Color Laser All-in-One Printer Questions & Answers
4answers
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
11/6/2021 3:46:44 PM • Samsung... • Answered on Nov 06, 2021
4answers
My Samsung CLX-3175 printer will
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
4/16/2021 9:23:41 PM • Samsung... • Answered on Apr 16, 2021
Replace Imagine unit Soon
Log into the service menu Samsung CLX-3175 without a numeric keypad similar to the unit Samsung SCX-4623F/FN:
Consistent set of combinations of
"MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK" . Samsung CLX-3175XX/X with a numpad press: Menu, #1934, Menu
The unit switches to English, if you installed any other.
In the menu appears TECH MODE.
In
Samsung CLX-3175 to enter the reset require a password 1934. The numbers by pressing "LEFT" - "RIGHT",
After each number press the "OK"
Good luck in the reset.
Have any questions, you here http://skit-ltd.narod.ru/
12/6/2019 1:53:45 AM • Samsung... • Answered on Dec 06, 2019
Printer stuck warming up
What kind of printer, HP will pop a 50 code which means underheat or overheat. Usually fuser replacment solves these problems, I would not leave it on they tend to melt plastic covers above printer.....
10/11/2019 4:45:26 PM • Samsung... • Answered on Oct 11, 2019
Samsung clx 3300 used to scan to pc but now it
I was not able to scan to the computer from the printer and I resolved the issue by selecting "Enable Scan from Device Pannel" in the "Scan to PC Setings" menu in the "Samsung Easy Printer Manager". Somehow, the default value for this option was "Disable" and my printer could not make the connection to the computer. After changing it to "Enable Scan from Device Pannel", I was able to scan the documents to my computer using the menu options from the printer pannel.
6/5/2019 9:33:18 PM • Samsung... • Answered on Jun 05, 2019
Samsung CLX-3175FN printer said "replace imaging
Hello, you can try this: Press: Menu, #1934, Menu, "Tech Mode " OK, "Data Setup" OK, > x7 to "Clear Counts" OK, "Enter Password [1934]", OK, "Clear Counts [Total Page CNT]", >x3 to "[Imaging Unit]" OK, "Clearing...", back
12/29/2017 10:33:42 PM • Samsung... • Answered on Dec 29, 2017
0answers
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
7/26/2017 12:41:35 PM • Samsung... • Answered on Jul 26, 2017
Can I print in Black and White only on this printer?
go to printer settings and select black and white only however as the printer is running color cartridges and they are empty you will always get that message it is not a good idea to run the printer with empty cartridges
1/20/2016 9:59:05 AM • Samsung... • Answered on Jan 20, 2016
6answers
Need to replace samsung clx-3175fn
I just replaced the fuser on this machine and the hardest part I think getting the right side cover off. The service manual was of little help the trick is to pry from the back and bottom. there are two little round tabs on the underside of the cover use a flat blade and pull. Once you remove the cover then I took the 4 screws out that hold the fuser. Then I lifted the fuser on the right side and traced the wires down to the board. There is a plastic piece on the right side of the fuser that sides into a gear. You have to slide to to the right to free the fuser. I used duct tape to keep the plastic piece and spring inside from falling out. Good Luck
11/6/2015 10:29:00 PM • Samsung... • Answered on Nov 06, 2015
Can you scan using ocr on CLX-3175FN
You can use OCR, the dpi is high enough, you just need the OCR software on your computer. There are no brains in the printer to convert the images.
10/17/2015 4:59:52 AM • Samsung... • Answered on Oct 17, 2015
Replaced black toner and drum. 1st page prints clean, the rest of pages are messy. Removed everything and wiped inside nothing showing on cloth.Everything seems clean. What else can I do?
Usually it's a dirty metal connector, but I will help you more if you reply my comment.
9/21/2015 8:04:56 AM • Samsung... • Answered on Sep 21, 2015
Printer says "scan unit open or paper jam 2" Hav...
Dear The printer paper jam-2 cover may be opened or not locked properly. This door is at back side of the printer. Thanks.
3/4/2015 12:57:17 PM • Samsung... • Answered on Mar 04, 2015
2answers
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
3/4/2015 10:32:33 AM • Samsung... • Answered on Mar 04, 2015
Samsung printer tries to print
If it same - tries to print, motor running, and start work of mechanism but not printing may be it's problem of pick up roller, roller has rubber, it tired. replace rubber of roller or wipe it with sandpaper carefully
12/31/2014 8:16:30 AM • Samsung... • Answered on Dec 31, 2014
Invalid imaging unit
there is a chip on the new drum that is bad. you need to return it to whom ever you bought it and they should replace it.
10/23/2014 3:34:14 PM • Samsung... • Answered on Oct 23, 2014
I have replaced imaging unit 2 months ago and now printer is telling me to replace it.
I assume that you made some alternation to the printer the it sense the change and blow the resistor of the imaging unit.all you need to do is check the resistor by the side of the imaging unit if it is blown replace it with same value but a stronger one.
10/8/2014 3:59:21 AM • Samsung... • Answered on Oct 08, 2014
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
404 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
replace imagine unit soon
  • Office Equipment & Supplies
