20 Most Recent
Sceptre X32BV-Naga 32 in. LCD TV Questions & Answers
I have a Sceptre X32 LED TV. It doesn't have any picture, sound or back light.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size...
5/28/2016 2:15:59 AM •
Sceptre...
Answered
on May 28, 2016
I have a sceptre TV 32 inch. I must have pushed a button on accident, it just cycles through colors and I cant get it to stop, no other buttons will work.
Try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
7/25/2015 3:18:52 AM •
Sceptre...
Answered
on Jul 25, 2015
Snowy picture
Check its Ariel cable for firmness. Check the orientation of antenna.
If all are correct, check and replace its tuner. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
4/7/2014 5:05:20 PM •
Sceptre...
Answered
on Apr 07, 2014
