20 Most Recent
JVC LT-32P679 32 in. LCD TV Questions & Answers
Red/orange color
If your set is led or lcd your Tcon board is getting to the end of its life, its the lowest cost board in a TV
Turn on power the power light lights up for few
The first step in troubleshooting this would be to perform a reset on the TV. You can do this by unplugging it from power for a couple of hours. Once you've done this, plug it back in and power it on and see if any issues persist.
If there is audio but no video you may be experiencing processor failure and some additional troubleshooting is going to be needed.
If there's no video or audio, chances are something caused the TV to short out somewhere. Most of the time the culprit is the actual power supply itself. The repairs on these aren't too difficult or pricey and if the TV is still under warranty you should be able to get it fixed for free.
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Why is my jvc TV not turning on?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Why won't my JVC LCD TV turn on?
If it doesn't turn ON at all; the fault should be with its main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
