20 Most Recent
Toshiba Satellite A305-S6863 Laptop Questions & Answers
Restarts
Your problem related to Drivers Up-gradation.Try to Upgrade BIOS Driver.For use your problem will be solved.I had the same problem and I did same thing. Thereafter my problem was solved
4/26/2013 4:26:45 PM •
Toshiba...
Answered
on Apr 26, 2013
Restarting
Try to Upgrade your BIOS.It will work for sure.I had the some problem and I did the same afterward problem solved.
4/26/2013 4:24:46 PM •
Toshiba...
Answered
on Apr 26, 2013
I have a toshiba a305
Your system is not producing video output after the POST, which means the Windows video is messed up or there is a problem with a component like memory.
Because you can see the Toshiba splash screen, it tells you the LCD screen is fine. At least you know the LCD screen is working. See if you can get into the CMOS setup screen. I think it may be by pressing F2 on startup. If you can get to that, make sure the hardware is correct (like seeing if your hard drive is seen as installed).
You can also try to press F8 on startup and start the computer in safe mode. Very possibly something is trying to start when Windows starts and not completing its startup.
5/23/2011 4:30:45 PM •
Toshiba...
Answered
on May 23, 2011
Need to clear the password
To reset the BIOS password read the information from this
link.
In case of your Toshiba Satellite laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
5/14/2011 10:48:51 AM •
Toshiba...
Answered
on May 14, 2011
Toshiba A305 shuts down randomly. Hard drive
More than likely it's from heat. The A305 gets hot quick, especially if your model uses the AMD processor. I would suggest you cleaning the machine out with some compressed air and verifying that you are running the latest bios revision for your model.
I've fixed lots of A305 just by doing the above ;)
Give that a shot, if it doesn't work let me know and I'll suggest more things you could try...but I'm pretty confident heat is causing your issues.
1/13/2011 12:56:29 AM •
Toshiba...
Answered
on Jan 13, 2011
I'm having problems with
Right click on My Computer, Properties and select Hardware tab. Click on Device Manager and click on Keyboards to expand. You will have a device called "Standard...", right click on it and select Disable or Uninstall.
11/29/2010 6:02:40 AM •
Toshiba...
Answered
on Nov 29, 2010
Tiene password en el bios
try this password "Toshiba" and then you can delete the password or change it to your desired one..
9/17/2010 2:05:37 AM •
Toshiba...
Answered
on Sep 17, 2010
