If you need to retrieve files from a USB storage device, it is as easy as using a dependable recovery program designed to perform USB data recovery. This software scans the sectors of an external device to locate and recover these items:
- accidentally deleted files
- corrupted data
- formatted USB drives
- lost or erased files
You see, a recent USB drive corruption or unexpected power outage can wreak havoc on your data. Even a simple file deletion may result in the loss of something important that you desperately need to retrieve. A USB recovery utility offers a reliable approach to quickly salvage your data. It can easily locate files on a USB device for retrieval. Whether deleted, corrupted, or erased during formatting, this program provides an opportunity to quickly get your information back. This video will walk you through the program.
USB Recovery for Mac Computers
try starting in safe mode by pressing f8 key on system boot , looks like you may have hdd problem, if you get message 0disks filling the screen hdd needs replacing
reprogram what. but if you want to bring in factory condition then when turn on power press ctrl and f10 together before booting it will go to factory restore menu from here you can restore windows to factory contion
From the information you give it sounds like you may have virus on your pc! Try to bot it from a live cd like some linux ditro(i.e. Ubuntu) and run an antivirus software. If that doesn't work your best choice is to format it. If that still doesn't fix it then it's probably a problem with your HDD and you have to take it to a repair shop
