20 Most Recent
RIM BlackBerry ® 8830 Cellular Phone Questions & Answers
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Unlock code 8852 blackberry
What's your Exact Blackberry phone model?You can get unlock code for your Blackberry phone from
UnBBLock.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.
Handheld unlock
Hi if you want to unlock your Blackberry 8830 mobile from network lock .Then visit
Mobile-Unlocker.com here they are providing unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ....
Blackberry 8830 passwors locked solution
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Looking for free unlocking code
As
far as i know free unlock codes doesnot work properly.please donot use
wrong codes its damage your phone.i am saying this because my friend
lost his phone by this.i know the site from where you get your unlock
code.its not free but it as much cheap as free.click here to get your unlock code.
hope this helps..
Unlockblackberry
Your Blackberry 8330 locked to which Network?You can unlock it easily using the unlock code,get that Unlock code from the site
Onlinegsmunlock.com and Unlock it step by step.Then use any GSM Sim card.
My gprs network will show
Good Day,
Please check your network settings. Go to MENU>MANAGE CONNECTIONS>MOBILE NETWORK OPTIONS
There you will see:
Data Services > which should be "ON"
Mobile Network> your providers name
Network Selection: >Should be automatic
Network Mode: > depends on your network provider(CDMA or 1xev on most North american networks)
just check these settings specially the Data Services that should be on, just click on it to turn on.
Also the network mode should be correct.
Lastly you may check with your subscription, If you have a subscription plan on your network that supports Data services. You may want to call your provider with this settings. Specially the BIS subscription. They would be just happy to help you with that in case it is not yet activated.
Hope this helps you. Thank you for using Fixya.
I have a new bb
Looks like you just change your original sim card with other network sim card. You must unlock your blackberry first before you can using other network in your phone. What you need is
blackberry 8830 unlock code from your original phone network sim card. You can get
blackberry unlock code from network provider or buy from third party sites which have lower cost rather than network provider.
