20 Most Recent LG WD-1080FD Front Load Washer Questions & Answers
My machine will not drain and the pre wash and
Replace drain pump
11/8/2017 3:47:08 AM • LG WD-1080FD... • Answered on Nov 08, 2017
Any videos on how to clean your water pump
You can check your user manual
11/9/2013 1:50:45 AM • LG WD-1080FD... • Answered on Nov 09, 2013
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
1/18/2013 8:09:38 AM • LG WD-1080FD... • Answered on Jan 18, 2013
6answers
My washing machine door wont open
Sorry for VERY late solution. I have an LG front loader machine and it has just broken. While surfing the internet, I found your blog. LG front loaders have a weak door handle, that breaks after a few years of operation. All the LG models seem to be the same. Replacement door handles are relatively inexpensive and readily available.To open your STUCK door, I would use a thin butter knife....slide the butter knife between the door and the frame of the machine until you hit the metal latch. Push the latch towards the centre of the machine and open the door.In the interim until you can get it fixed, this workaround method will work, enabling you to continue washing.Hopefully LG will make future models door handles out of cast, or something stronger!
7/14/2012 7:33:45 AM • LG WD-1080FD... • Answered on Jul 14, 2012
0answers
0answers
Drum starts to move then stops then Le appears
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
8/11/2011 1:00:07 PM • LG WD-1080FD... • Answered on Aug 11, 2011
My lg washing machine front
'CL' for LG washers stands for 'Child Lock'.
To release hold down 'temp' and 'eco/rapid' together, then release!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
6/28/2011 3:30:36 PM • LG WD-1080FD... • Answered on Jun 28, 2011
Circuit of LG 6871EC1024Q
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will need to type into your search engine/web browser '(make model number) washer technical manual' and you MAY be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct but many will only supply to registered repair companies;-0(
John C.
6/28/2011 11:06:08 AM • LG WD-1080FD... • Answered on Jun 28, 2011
0answers
Water spraying from cold water
change the hose or change the water valve inspect if the threads on the water valve are damaged if the threads arent damaged on the water valve then change your hose if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation thanks again
Rick
12/13/2010 4:23:14 AM • LG WD-1080FD... • Answered on Dec 13, 2010
My dryer keeps saying check
well i don't know but i'd ck the filter . there is probably a clog or blockage in the air vent . the discharge . try removing the vent and dry a load and see if it works better .. air flow is most important with dryers .. mm hope this helps feed back please .. majic **** .
11/10/2010 5:55:18 AM • LG WD-1080FD... • Answered on Nov 10, 2010
I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
10/22/2010 6:55:33 AM • LG WD-1080FD... • Answered on Oct 22, 2010
LG WD-1080FD Front Load Washer Logo
55 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
  • Washing Machines
