20 Most Recent Kohler K-T462-X4V-CP Memoirs Rite-Temp Pressure-Balancing Shower Faucet .... Questions & Answers
My heater stops working in the middle of the night
the Model number you gave is for a Shower Head what do you mean it doesnt heat... it only conrtols the water temp by BALANCING the hot and cold water inlets does NOT heat anything if your water is cold then check another PLAIN faucet to see if your water is the same temp( cold) if it is the hot water from water HEATER is cold nothing to do with faucets
11/22/2009 1:51:06 AM • Kohler... • Answered on Nov 22, 2009
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps: First, turn off the water supply to the faucet. Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key. Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off. Once the plastic insert is removed, you should be able to access the cartridge. If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
1/14/2024 12:29:26 PM • Kohler Plumbing • Answered on Jan 14, 2024
Manual and guide to replacing parts in Kohler Model 10430
Parts diagrams. Instruction for changing are normally on the Kohler website. Or Google make model replace (the part). https://www.google.com/search?q=kohler+model+10430+replacement+parts ..
12/4/2022 12:47:33 AM • Kohler Plumbing • Answered on Dec 04, 2022
2answers
Have Taboret K 8201-4 bathroom faucet with T handles.
Question edited to fix the typos. Always worrying when they discontinue lines, and it makes you wonder why? https://www.us.kohler.com/us/taboret-centerset-bathroom-sink-faucet-with-lever-handles/productDetail/product:420060/420060.htm I normally find that they use steel screws and they stick. Make some sort of a dam around the screw with stout polythene like Ziploc bag and electrical tape to seal the base. Then squirt penetrating oil or WD40 in there to cover the screw head. Top it up a couple of times a day and do that for two days. That should loosen it up and get the oil down the threads. Often it is just easier to buy a new set.
9/23/2022 12:45:42 PM • Kohler Plumbing • Answered on Sep 23, 2022
Tines stripped on recessed aerator how to remove
call kohler
12/13/2021 11:09:03 PM • Kohler Plumbing • Answered on Dec 13, 2021
Is there a video of replacing o ring on a 77809/AA kohler leaking under handleplease
you tube is the video website
5/28/2021 5:05:40 PM • Kohler Plumbing • Answered on May 28, 2021
Kohler one handle shower faucet fixture will not turn off
Look up the Kohler 800 number. Their parts have a lifetime warranty and they will gladly send a replacement part.
11/6/2019 10:53:41 PM • Kohler Plumbing • Answered on Nov 06, 2019
Is there suppose to be a o ring at the bottom when replacing a kohler taboret cartridge
I assume you mean the separate H/C valve body as opposed to single handle(bath/shower). https://www.us.kohler.com/us/Taboret-t-handles/productDetail/product:417141/417141.htm?skuId=341208 There is one O ring just below threads of body. k1-5ywlvxu2h1hgmzvnljvnapjw-2-0.png
4/22/2019 10:42:13 AM • Kohler Plumbing • Answered on Apr 22, 2019
2answers
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
12/26/2018 1:35:54 PM • Kohler Plumbing • Answered on Dec 26, 2018
The handle on my Kohler ASME A112.18.1 bridge faucet is loose. How do I tighten it?
Pop the cap off the faucet handle and tighten the screw under it.
11/15/2018 9:03:22 PM • Kohler Plumbing • Answered on Nov 15, 2018
Hot water comes before cold water for Kohler Mixer Pressure Kit
If this is a tub/ shower valve, you installed the cart. upside down. Reversing it should solve the problem. You might have put it in according to instructions but the hot and cold might have been reversed when the valve was plumbed in.
10/8/2018 1:10:22 AM • Kohler Plumbing • Answered on Oct 08, 2018
2answers
Dripping kohler faucet
replaces the tap washer or insert
10/8/2018 1:08:12 AM • Kohler Plumbing • Answered on Oct 08, 2018
2answers
We have Kohler wide spread Bancroft metal handle sink faucets. The left handle is wobbly from the base of the handle there are no Allen holes or screws how can I fix this?
The bottom half of the handle spins CCW to losses the handle from the body. You can then tighten the screw inside the handle.
10/8/2018 12:58:59 AM • Kohler Plumbing • Answered on Oct 08, 2018
2answers
Where is the brand name printed on a kohler kitchen faucet
There is normally a tag on one of the supply lines.
10/8/2018 12:49:37 AM • Kohler Plumbing • Answered on Oct 08, 2018
My Kohler Forte K-10270-4 bathroom faucet leaks just below the hot water handle. The water dribbles out from the top of the flange that attaches the handle. What Kohler parts do I need to fix this?
It takes new valve cartridges and sometime complete valve bodies. Call Kohler, it should be covered by their lifetime warranty. They are very good about service.
10/7/2018 8:28:19 PM • Kohler Plumbing • Answered on Oct 07, 2018
Kohler K-T462-X4V-CP Memoirs Rite-Temp Pressure-Balancing Shower Faucet .... Logo
Popular Tags
1 questions posted
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Kohler Plumbing
  • Kohler Plumbing
Most Popular Question
heater stops working in middle night
  • Plumbing
