20 Most Recent
Bosch Brute Breaker Hammer 11304 Questions & Answers
Started smoking from trigger
Maybe there is a interference suppression capacitor for radio supression near the switch have to only remove it . i do it by the most Bosch powertools because it made more problems than the purpose for which they are.
The ultra short wave radio listeners are not much more today everywhere its DAB+ do not suffer
My hitachi jackhammer runs slow and gets hot
The armature AND electric field must together replaced to get a safe working again, and the defect will not repeat if it be shure have its operating hours on it and give a full service.
Bosch gbh5 will keep loosing its hammer
It sounds like the gearbox oil is getting low. The GBH5 uses oil in the gearbox, not a grease - the grease is used for assembly only. The correct type is a PG-150 (fully synthetic gear oil). Unable to find it in small quantities, I now use PAG150 oil for automotive a/c systems, it's available in small bottles. As for quantity, no-one seems to know... I just fill to cover the big bottom gears.
11304 034
what caused grees to round down chissel from bottom of tool
My jackhammer will not run, the cord and switch are good
Check your brushes. The brushes on the Brute breaker have a spring loaded, non-conductive pin in them. When either brush wears down far enough the pin pops out and prevents damage to the expensive armature. If by chance the brushes are OK you may have to have your armature tested.
