20 Most Recent LG DLE2512W Electric Dryer Questions & Answers
Seam came apart on access panel to rollers on my dryer
Post a photo
8/8/2017 5:02:00 AM • LG DLE2512W... • Answered on Aug 08, 2017
LG dryer DLE2512W power up but won't run when press start button.
Check for broken belt. Take top off to check.
7/29/2017 4:29:28 AM • LG DLE2512W... • Answered on Jul 29, 2017
How do you get the top off a kenmore dryer
remove screws in back, slide top back about four inches, left off.
3/3/2015 5:20:50 AM • LG DLE2512W... • Answered on Mar 03, 2015
Lg dryer replace drum rollers
never lubricate a drum roller ,it will attract lint and hold it like a magnet possibly making your problem worse. graphite lube possibly - as used in door locks.but this will be only a temporary fix. replacement is the only way to go.
2/1/2015 11:50:00 PM • LG DLE2512W... • Answered on Feb 01, 2015
LG electric dryer is not working
Reset your electric breakers and make sure the door switch is working. If not sure on switch after resetting breaker turn dryer on and with open door press the door switch in .caution keeps hands from inside in case it starts to work It also could be a Senser inside of dryer that goes off if vent is plugged with debri
6/1/2014 10:13:21 AM • LG DLE2512W... • Answered on Jun 01, 2014
Dryer on sensor dry - gets stuck on 6 minutes and does not finish
We have been having this same problem. I had tried adjusting everything that I could think of when putting a load of laundry in and got the exact same results as you. I would select the sensor dry and it would count down just like normal until it got to 6 minutes and then it would just run forever at 6 minutes.
My husband and I searched online all this afternoon and came across what seemed way to simple to work. We removed the lint filter, unscrewed the filter housing right inside the door of the dryer, and got to the sensors. We took a damp cloth and wiped them off very well to remove any and all buildup. We wiped everything down very well to remove any built up lint and/or dirt and put everything back in place as was before. We then unplugged the dryer for about a minute and then plugged back in. We put a load of already dry clothes into the dryer and started as usual with the sensor dry. It started out at the usual 41 minutes then skipped down almost immediately to 6 minutes and then a few minutes later I heard the most beautiful sound I have heard in a long time. The Beeper signalling that the timer had counted down to the end and was finished. It had worked. Thankfully. Hope this helps you also.
5/9/2014 4:35:11 AM • LG DLE2512W... • Answered on May 09, 2014
0answers
On lg tromm
Be the first to answer 3/10/2014 5:30:31 PM • LG DLE2512W... • Posted on Mar 10, 2014Be the first to answer
0answers
Flow sence
Be the first to answer 3/10/2014 4:32:36 AM • LG DLE2512W... • Posted on Mar 10, 2014Be the first to answer
0answers
2answers
Cracked Drum on LG Dryer Model #DLE2512W
If you are still looking for information on this:
No, there has not been any recall.
It is not a real common problem. I only see 1 or 2 a year, which is not many. (LE errors on washers are much more common, for example) The part number of the drum for a DLE2512W dryer is 3045EL1002D and lists for just over $100. You can find a service center to order the part from (in the US) at http://us.lgservice.com/index_b2c.jsp
I would rate the repair at about a 5 or 6 out of 10 on a scale of 1-10 in difficulty. (Basically, remove top, remove front control panel, remove front panel, remove front drum support, remove belt, drum comes out the front, reassemble.)
1/26/2014 4:03:27 AM • LG DLE2512W... • Answered on Jan 26, 2014
Drum wont turn unless i manually start it and close the door
bad belt or worn out drum wheels
12/19/2013 8:13:54 AM • LG DLE2512W... • Answered on Dec 19, 2013
0answers
LG DLE2512W Electric Dryer Logo
155 questions posted
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
lg dle2101w disassembly
  • Dryers
