20 Most Recent
LG DLE2514 Electric Dryer Questions & Answers
Dryer won't turn off.
Is it a mechanical timer you turn (the "clickety-clank"-kind) to set the time? Sounds like something in it has been worn out. Shouldn't be too hart to get a replacement for it,t and you should also probably be able to replace it yourself unless you're very "un-handy", or want to play it safe.
Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
My dle2514W LG electric dryer is displaying a CL
My dryer had this same problem. I cleared it by unplugging the dryer from the wall for 20 seconds and then plugging it back in. After this "reset" of the electronics, it has functioned for 2 days without a problem.
Dryer says check filter and it is clean
Air flow in the duct work is restricted... and the dryer sensor thinks that the filter is clogged.
You will need to take a fluffy cleaning wand and, with the filter removed, try loosening up some of the accumulated line in the duct.
Next, remove the lint pipe from the wall connector and try cleaning it and the pipe for as much distance as you can reach.
Finally, go outside and check the vent. It needs to be clean and clear of obstructions... also, needs to close when the machine is off.
You can do testing on the outside vent with "air dry" setting - hot air is not required... Keep cleaning ductwork until the outside vent passes air freely.
After air flow is restored, the sensor in the "VENT" alarm will act nice.....and stay off
Where is the sensor
If you're talking about the moisture sensor, it's located in the lint filter casing. Remove your lint filter and look inside the casing. About 4 to 6 inches down on the right-hand drum side of the casing and running to the center, you should see two flat metal arcs following the contour of the casing. These metal arcs are the moisture sensors
Lg dryer wont start lights on on but wont start
Check the thermal fuse, start switch on the control panel and door switch because all three are more likely the cause of the dryer not starting up.
The door switch is often the culprit in this type of fault, although a faulty drive motor is not ruled out.
How to turn off the child lock on a dryer
This information is from the manual:
Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
