20 Most Recent LG DLE2532W Electric Dryer Questions & Answers
The add water light flashes on my LG dryer, even when the tank is full.
I had this problem and I was able to fix it. The water pump was fried. That pump is between the water reservoir and the steam generator. It apparently is the water detection sensor as well. The part was easy to replace-- it's literally a drop in part. All you need to do is take off the top of the dryer, unplug the leads to the pump, pull it out, and put the new one in. The part was about $100.
11/26/2022 3:56:33 PM • LG DLE2532W... • Answered on Nov 26, 2022
I have an LG DLE2532W dryer. It suddenly stopped
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube, repairclinic.com, appliancepartspros.com
6/12/2017 5:00:03 AM • LG DLE2532W... • Answered on Jun 12, 2017
5answers
No heat in dryer and can't find reset button
Unplug the dryer. Disconnect the vent hose from the wall and clear any lint etc. from the opening. Anything clogged with lint will continue to cause the heating element to "trip" for safety reasons.
Open the top by pressing in on the hidden metal clips on the right and left front (there is a small gap below the top section) Use a putty knife or screw driver to press in on the clips. Lift up like a car hood and then prop it up while you're working. Next open the dryer door. Remove the two screws on either side of the lower opening. Now lift the front up and out, set off to the left side as it is still connected by a wire. Look into the lower right side of the dryer with a flashlight. The reset button is located between the two wires that attach to the outside of the cylindrical drum at the 7 o'clock position. You need to be lying on the floor so you can reach your hand in. It is about halfway into the dryer. Press the button. Now reassemble the dryer before you start it up again. For a gas dryer - let it run and you should hear it "fire" up within a minute and the heating will begin.
5/21/2017 9:54:43 PM • LG DLE2532W... • Answered on May 21, 2017
2answers
Dryer starts then stops 10 seconds later for 1 minute then starts again
You dryer has several "overheat thermostats" located at various places inside your machine.They are to prevent fires caused by overheating. I suspect one of them is defective, or you have another problem which is causing one to shut your dryer off. The dryer is shutting off to prevent a fire.Be blessed
4/2/2017 1:13:10 PM • LG DLE2532W... • Answered on Apr 02, 2017
3answers
Hi need to order parts were can i get them
Hi
Thanks for using FixYa. You can order the parts from any of these two links:
LG DLE 2532W Parts
LG DLE 2532W Parts-2
Please do rate thesolution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1/17/2017 9:38:58 AM • LG DLE2532W... • Answered on Jan 17, 2017
2answers
How do i reset the memory for my beko sensor
Pull the plug and wait 1 minute to reset the computer.
3/31/2015 5:01:08 PM • LG DLE2532W... • Answered on Mar 31, 2015
Replacing rollers on lg DLE2532w dryer
check out video at appliancepartspros.com
3/3/2015 5:06:47 AM • LG DLE2532W... • Answered on Mar 03, 2015
How do I get to the heating thermostat
I think you can "pop" the top off using a screwdriver..... It might be the heating coil. Look for breaks in the coil or can use a volt/ohm meter to check it...
10/28/2014 4:11:55 PM • LG DLE2532W... • Answered on Oct 28, 2014
5answers
LG DLG2532W Gas dryer problem
dryer working and heating properly, when cycle complete all my clothes smell like gas though. Any suggestion
9/7/2014 11:45:40 PM • LG DLE2532W... • Answered on Sep 07, 2014
Where is the humidity sensor on an lg gas dryer
With the drum out, facing the dryer, it's on the left side, mounted on the exhaust baffle, close the the high limit thermostat. It has one wire leading to it.
7/21/2014 7:42:53 PM • LG DLE2532W... • Answered on Jul 21, 2014
How do I recover pen which dropped thru my filter trap?
This could cause motor fan system to lock up if gets caught in fan also could brake open staining clots should be taken apart and recovered b4 useing front of dryer need to come off
7/15/2014 8:39:55 PM • LG DLE2532W... • Answered on Jul 15, 2014
Reset button
There is no reset button on this machine, by turning off the power for about 2 to 3 minutes the memory on the control board will clear. Failing this, there is a problem on this control board.
7/5/2014 8:48:19 AM • LG DLE2532W... • Answered on Jul 05, 2014
2answers
How to reboot the computer on an electric LG dryer
To reboot the computer turn the breaker off waite a few minutes and turn back on. The breaker is not part of the dryer but it is located in either the main box or one added for the dryer.
6/11/2014 12:16:02 AM • LG DLE2532W... • Answered on Jun 11, 2014
My dryer's controls are locked
child lock is on
To enable the Child Lock feature: Press and hold RACK DRY and ANTI BACTERIAL for 2 seconds. A single DEEP Tone is heard, and CL is displayed. To unlock, press and hold RACK DRY and ANTI BACTERIAL for 2 seconds. The indicator light turns off.
i hope this was useful
5/28/2014 2:46:47 PM • LG DLE2532W... • Answered on May 28, 2014
LG DLE2532W Electric Dryer Logo
347 questions posted
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
dle2532w lg dryer dryer start
  • Dryers
