20 Most Recent
Schiller Cardiovit At 2 Light Ecg Machine Questions & Answers
Schiller at-2 macine, autoprint function
Likely your paper is loaded incorrectly or is incorrect for the unit. The auto print format depends on the position of the black "que" mark in the paper, but the manual mode does not. Be certain that the paper is correct for you unit. If that isn't it, then you que sensor could be dirty or defective. THis would require shop level repair, as dis-assembly of the unit is required.
4/17/2015 2:34:39 PM •
Schiller...
Answered
on Apr 17, 2015
Why won't it turn on?
Sounds like you need a new battery. When they go dead you will still see the green light but it will not turn on or only on for a second.
4/17/2015 2:21:52 PM •
Schiller...
Answered
on Apr 17, 2015
I have a AT2 Plus machine and cannot find my
To change the Time :
- Firstly, press the following key sequence : ALT, 9, 1, 1
- Then, enter the time (HHMMSS)
- Finally you'll hear the confirmation beep
To change the Date :
- Firstly, press the following key sequence : ALT, 9, 2, 2
- Then, enter the date (DDMMYY)
- Finally, you'll hear the confirmation beep
9/26/2013 5:41:07 PM •
Schiller...
Answered
on Sep 26, 2013
High, I have a Schiller
hi,
Your machines thermal printing head have some problem. Thats why it give printouts very light. Not possible to repair thermal head. You have to replace it.
ok
12/13/2011 1:43:30 PM •
Schiller...
Answered
on Dec 13, 2011
My machine will not turn on
Greetings. The schiller AT2 is battery powered. It will power on when plugged in however even with a dead battery, but if the battery is REALLY bad, we have seen it load the power supply preventing power up. On the top of you unit there is a small green "AC" indicator that should be illuminated when the at2 is plugged in. If it doesn't, your power cord might be bad, try a new one. If that doesn't fix your problem I would try at least to replace the battery. The battery requires dis assembly to replace, and there are three cable attaching the top case to the PC board. If you pull it apart to far without detaching the cables, you will do expensive damage. Also the removal of top case exposes high voltage, so this should never be undertaken a. with the unit plugged into a wall outlet, or b. By an unskilled individual. I would recommend that you find a local bio-medical contractor, or other service company, and have the battery changed. If your chosen contractor replaces the battery and the problem remains, your main board likely needs replacement, again by a qualified individual. Be warned however this in a very expensive part. There are several other possible problems, but very few that are operator serviceable. Best of luck!
11/21/2011 2:21:34 AM •
Schiller...
Answered
on Nov 21, 2011
The schiller At-2 we have in the office is acting
HI,
check the paper u have inserted. it should be Schiller original paper
with page marking. also clean the paper sensor. u can see the paper
sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
7/19/2011 7:12:56 PM •
Schiller...
Answered
on Jul 19, 2011
At-2 lite model not printing
hi,
check the paper you have inserted. if the paper quality is bad then the printing can become bad. Use schiller original paper.
if again printing is bad then the thermal printing head of you machine is faulty or the. you have to replace the same.
ok
4/18/2011 3:47:06 AM •
Schiller...
Answered
on Apr 18, 2011
One of my stylus seem out of contact with the
hi,
there is a pressur adusting facility inside for the thermal printing head. u can adjust it for quality printing. for adjusting the same i will prefer use the help of a qualified person.
ok
12/23/2010 10:17:27 AM •
Schiller...
Answered
on Dec 23, 2010
Printing 3 leads only not 12
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site
http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
11/4/2008 2:22:16 AM •
Schiller...
Answered
on Nov 04, 2008
