20 Most Recent
LG GC-051SS Compact Refrigerator Questions & Answers
There is ice buildup on
Your unit is NOT frost free according to the specs so it will required periodic defrosting to keep the ice build up from affecting the fan.
What is the wattage of
If you can find the nameplate on the unit with Model and serial number, there should also be a rating for amperage draw, multiply that number by 120 to get watts. I f this is a compact unit it probably uses 1.5 to 3 amps
Fridge is too cold even on mid setting, food is
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Check out these tips...they can help you figure out whats going wrong with your
refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Just bought a used LG gc-051ss mini fridge. The
There is a self timer for auto defrosting in the no frost model. There could be possible fault in this setup. Also your thermostat could be another culprit. You will need to call a service technician to give an second opinion but keep these views in mind. Never try to do any work which could be expensive to already a wrong choice of buying a used set w/o warranty. Finally keep your thermostat in diffferent modes and check out for any differance in the fault. Hope my advice is helpful. Good Day.
I punched a hole in the freezer what can I do to
If you poked a hole in the cooling tube and the freon came out, you'll have to call a qualified tech to repair the hole and recharge the system.
If it's just a hole in the wall or something you can just plug it up with anything to prevent air leaking.
