20 Most Recent Hansgrohe E & S Accessories 40526000 Polished Chrome Toilet Paper Holder Questions & Answers
I've just fitted a Nabis breeze and am having flushing problems.
Well many toilets flush very high before flushing, they appear to almost overflow, but if that doesn't seem like your problem, I would recommend adjusting the float on the Fluid-master fill valve so that there is less water in the tank when it flushes.
5/18/2010 8:33:19 PM • Hansgrohe E & S... • Answered on May 18, 2010
2answers
How to Install Toilet Paper Holder?
I can't unscrew the toilet paper holder from the wall to move it to a different place. There is only one tiny screw underneath, hard to see and it does not move????? appreciate any advice. Thanks.
1/31/2009 10:02:08 PM • Hansgrohe E & S... • Answered on Jan 31, 2009
2answers
Hi, I purchased a Hansgrohe Raindance S 100 AIR 3-Jet Handshower last year. Lately, some amount of water seems to be coming out between the grey plastic and the outer-housing (instead of through the h
Hello david41139, This is a sign the spray face is getting clogged or slowed by water deposits. When this happens it will slow the water going through the venturi in the head and begin to express water in the areas it would normally draw in air. The first thing to try is to soak the spray face in CLR. Follow the instructions on the container for use of the CLR. It will most likely instruct you to dilute. Then rinse the head well. Reconnect the head and run water through it. While running you will need to rub the rubber water channels in the spray face. Then repeat the process at least two more times to remove all the deposits. If you need any further assistance give me a call at 1-800-334-0455. Press 2 for tech and ask for David. I will be happy to help.
6/10/2023 6:16:43 PM • Hansgrohe Home • Answered on Jun 10, 2023
Leaking shower head in older Hansgrohe model. Will wall plate with dual valve solve it?
no it wont, you need a washer where the leak is coming from
12/26/2018 11:37:31 PM • Hansgrohe Home • Answered on Dec 26, 2018
Leaking at the ball joint..how can i fix the shower head
undo the nut that holds the shower head on ( bit behind the ball) and inside there is either a rubber washer or a fiber washer replace that and do it up
8/19/2016 10:29:07 PM • Hansgrohe Home • Answered on Aug 19, 2016
How do a fix a cold water leak coming from the faucet?
Read the Assembly Instruction (Finish Set) found at http://spares.hansgrohe-usa.com/etk/US/product/04465000/8802057498467.seam?fsid=0x0000771100006CC100007701&lang=en_US&wcms=US on the Hansgrohe website. I chose the Focus S Shower System Combination Set, Article No# 04465000, because it's sort of generic and typical. Part # 88727000 will solve your problem
11/3/2015 3:00:36 AM • Hansgrohe Home • Answered on Nov 03, 2015
How do I adjust hot water safety on shower
Some mixer valves are slightly different. Can you post a picture of what you have?
1/23/2015 8:24:30 PM • Hansgrohe Home • Answered on Jan 23, 2015
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same. Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
1/12/2015 1:59:20 AM • Hansgrohe Home • Answered on Jan 12, 2015
How do you unscrew hansgrohe axor carlton showerhead?
It would be the reverse process as illustarted in yhe "how to" install video...http://youtu.be/11xZMhO_h18
7/29/2014 2:07:37 AM • Hansgrohe Home • Answered on Jul 29, 2014
Hansgrohe E & S Accessories 40526000 Polished Chrome Toilet Paper Holder Logo
3 questions posted
Top Hansgrohe Home Experts
James
Level 1 Expert
Kevin Cumberland
Level 1 Expert
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
View Most Popular
Hansgrohe Home
  • Hansgrohe Home
Most Popular Question
install toilet paper holder
  • Home
