20 Most Recent Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23 Questions & Answers
2answers
Lincoln Pro-mig 175 w/ no wire feed but relay clicks fan runs
is the unit set for the right input voltage.
12/6/2017 1:34:06 PM • Lincoln Electric... • Answered on Dec 06, 2017
2answers
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
8/1/2014 8:36:38 PM • Lincoln Electric... • Answered on Aug 01, 2014
2answers
My mig wire melts inside base unit when trigger is pulled
Your liner is grounding some place make shure the tip is not touching any thing but the answer to your question is there is a direct short in your feed hose or tip or liner
12/9/2012 7:41:07 AM • Lincoln Electric... • Answered on Dec 09, 2012
3answers
I have a brand new Lincoln pro mig 140. Took it
I'm having a problem with the wire feed on my Lincoln Pro Mig 140. The wire feed speed is not consistant. It seems to be slipping even though the tension is tight. Any solutions?
11/4/2012 9:22:07 PM • Lincoln Electric... • Answered on Nov 04, 2012
No wire feed
If the power to the unit/fan is on and the relay clicks the fuse is not the problem. Check your motor connections. Either you have a bad motor/wiring to motor or motor speed control board.
5/30/2011 3:44:10 AM • Lincoln Electric... • Answered on May 30, 2011
I have a ProMig 175.
Verify the polarity is correct for Flux or Mig configuration (should be on label under lid) - and ensure there are no loose connections on that polarity wire.
Loosen the tensioner + make sure the wire feed motor turns freely by hand.
My WeldPak 100 and SP-135T were tough to turn, but it did turn freely.
If it does spin freely, then inspect the contacts for the voltage selector. Make sure to unplug the power cord and keep clear of the big capacitor. My SP-135T contacts corroded while in storage.
4/13/2011 4:39:16 AM • Lincoln Electric... • Answered on Apr 13, 2011
Hola deseo q todos esten
Necesitas jalar todo el cable fuera de la pistola, el cable nuevo no lo va a empujar solo se va a atorar.
1/14/2011 3:10:46 AM • Lincoln Electric... • Answered on Jan 14, 2011
0answers
2answers
Wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
4/24/2010 5:48:49 PM • Lincoln Electric... • Answered on Apr 24, 2010
Lincon sp 200 wire feed roller does not turn so no
Bad motor, wiring or speed control board
9/22/2009 1:33:07 PM • Lincoln Electric... • Answered on Sep 22, 2009
Lincoln Electric Mig Welder-Fuse question
dont know what unit your uncle has but here is a easy test,open unit go to feed motor unplg the connector have unit running pull gun trigger check for voltage at plug ,if no voltage trace wires back (with the unit unplug , for your safety)probably will go to one side of main contactor.restart unit being careful for this is main input power.if no power main contactor is bad .if you have power at motor plug(wire feed motor) the motor is bad. hope this helps your uncle.
7/12/2009 11:56:18 AM • Lincoln Electric... • Answered on Jul 12, 2009
Lincoln 175hd mig will not feed.
Make sure your roller motor is spinning. If it is, then adjust the rollers tight enough to spin out the wire. If power is available and motor does not spin, check the fuse on the control board. If it is ok, then it is your control board.
5/6/2009 9:42:43 PM • Lincoln Electric... • Answered on May 06, 2009
2answers
Lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
3/6/2009 7:16:37 PM • Lincoln Electric... • Answered on Mar 06, 2009
Connect ln 9 gma to miller xmt 304 inverter with 14pin recep.
One of your pins isn't wired correctly for your combination.
2/12/2009 4:21:35 AM • Lincoln Electric... • Answered on Feb 12, 2009
Mig replace tip
Pull off the extreme outer nozzle of the MIG gun. Clean the inside of this nozzle with MIG pliers or round wire brush. Unscrew the welding tip. (If it is stuck, try using a pair of pliers lightly). Clean the entire area with a regular wire brush. Screw on the new tip finger tight, but snug. Replace the outer nozzle.
2/10/2009 11:14:15 AM • Lincoln Electric... • Answered on Feb 10, 2009
My pro cut 55 Lincoln plasma cutter sounds like a machine gun when I strike it and put it to the metal. It cuts holes when you hold the trigger down and try and make a continous cut. new air dryer
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjs8bCkuK6DAxWckIkEHe3TDjsQFnoECBMQAQ&url=https%3A%2F%2Fweldingweb.com%2Fvbb%2Fthreads%2F710111-Lincoln-Pro-Cut-55-Problem&usg=AOvVaw0cDjkvgYBijIMdD5HSUUUq&opi=89978449
12/27/2023 1:15:05 AM • Lincoln Welding... • Answered on Dec 27, 2023
Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23 Logo
Popular Tags
30 questions posted
Top Lincoln Welding Tools Experts
Sean Wright
Sean Wright
vince
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Lincoln Welding Tools
Most Popular Question
promig 175
  • Welding Tools
