20 Most Recent
Astro Pneumatic 3 Pk. MIG Welder Torch Tip - .023" - 4023, by - Astro Pneum Questions & Answers
My welder just stopped
your feeder may need adjusting or more commonly the tip has tacked itself on the edn cap
keep the line as straight as you can & keep feeder compartment clean!
keep plyers handy for when wire is stuck in the tip
if you need to replace wire spool or a brakage of the wire make sure the wire is free or BURRS b4 you put it in the tube or you will damage the tube!
Cheer Rob.
MIG 250 welder torch tip
its a Hobart copy. Use tips intended for a Hobart, and always be sure to use tips that are for the same gauge of wiring you'll be using.
I HAVE A POWER MIG 110 DOES NOT FEED WIRE UNLESS
Hi:
If your drive rolls need an extra pressure on them, that means you are using an oversize rolls, you did not mention what kind of wire is it (solid or fluxcore) probably your drive rolls are 035.
If youa re using fluxcore wire (no gas needed) the you should buy a knurled type roll that will cure the problem. Your machine is capable to weld up to 3/16" thickness using flux core wire or 10 gauge using solid wire-gas.
If this was useful to you please vote, thanks.
Drive wheels slip and won't feed wire. tensioner
make sure your drive wheels and contact tip is the right ones for the size of wire you are using. if your tensioner is too tight it will crush your wire and it will not feed through your contact tip.
loosen off your tensioner and remove any wire that has gone through your drive wheels.
I have a Hobart 10000
It sounds like your soft arc or arc start exciter is going bad. This should kick up the engine immediately, when you strike an arc. If you keep the welder on a truck, this is a common problem. Although Hobart makes a fantastic machine, all welders kept exposed to the elements have this problem from time to time. Before replacing parts, I would clean ALL contact points and replace any that are burnt or pitted. Sometimes, it will save you a bundle.
Burned resistors
I have the same problem with the Mighty Mig...Did you find these resistor values?
Century 100 wire feed welder free download manual
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX5_3Gt66DAxVCC3kGHUEmCY0QFnoECA0QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fproducts%2FCentury-Wire-Feed-100-4113584.html&usg=AOvVaw3kmdPZSNde6Hkk_kq3bVxZ&opi=89978449
